Replaced the belt and alternator on my tri pak now when I have it on a mode it over charges my inverter the display shows 15.7 volts but the display for my truck batteries shows 13.8 when I turn the key on...any ideas....btw it the older unit on an 07 columbia....thanks
Apu over charging power inverter.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Goober01, Jul 25, 2017.
I once had a positive wire in my battery box that had worn thru the insulation and was grounding itself on the box. Made my volt gauge read over 15 volts was the way i knew I had an issue. Maybe look for a shorted wire in the work you recently did.
I have a 2014 tripac. Not all the time but sometimes it charges up to 15 + volts and only shuts off when it throws a code. They just put a new computer control box under the bunk. ??? And I put new batteries in the truck last month. Any ideas
I had the same thing happen with my tripac. Never could figure it out
