apu question
Discussion in 'Experienced Truckers' Advice' started by tmb0507, Feb 15, 2015.
  1. tmb0507
    tmb0507 Medium Load Member
    357
    197
    Aug 11, 2012
    Folkston, GA
    Almost postive this is a dumb question but my carrier apu will start and then shut off I get a low voltage message is this just due to my truck sitting for 12 hours not running or could it be something else
  3. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    it should start when its low to recharge the batteries.
    i just had to jump mine to start, battieres were too low to start, its humming along now
  4. skootertrashr6
    skootertrashr6 Medium Load Member
    639
    6,942
    Jan 4, 2012
    Pueblo, Co
    It's possible the alternator on your apu might be done for, thus shutting itself off so it doesn't completely drain your truck batteries and you can start your truck.
  5. tmb0507
    357
    197
    Aug 11, 2012
    Folkston, GA
    Looks like it was just from truck sitting all day let truck run and charge everything back up seems good now
  6. EZ Money
    EZ Money Road Train Member
    That or the belt is slipping....one of the two.
    Mine has done the same thing before,run a bit and shut off...reading low voltage.
    It was the belt.
  7. Aminal
    Aminal Heavy Load Member
    Carrier APU should only start and stop if you tell it to by setting it in COMFORT MODE or TEMP START MODE or BATTERY MONITOR MODE. It shouldn't kill itself if the truck batteries get low. The opposite. If in BATTERY MONITOR mode, it should START to recharge the batteries. It's part of Carrier's "Limp Home" feature that lets you turn on the APU to run the truck's electricals if the truck's alternator fails and the batteries get too weak to keep your engine running.
    I'll give Carrier this: you can set the bunk control to make it sing, dance and whistle a tune. I'll knock 'em on; if you set the controls wrong (which is SUPER easy to do), it will come ON when you don't want it to and shut OFF when you don't want it to. Three different modes and settings within each of those modes and Sheeze!! TK beat the $#!+ outta Carrier with simple controls: BUT you can't use a TK to take the place of your truck's alternator and batteries if they go tits up.
    If it was me and my Darla; I'd get to a Carrier place and let THEM look at what's going on.
  8. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,144
    Apr 1, 2011
    Broomfield, CO
    Take a voltmeter and check the voltage at the nut on the back of the alternator. If that checks out at 13.6 - 15v, it's either in your wiring, or something in the CECU is going haywire.
  9. tmb0507
    357
    197
    Aug 11, 2012
    Folkston, GA
    After I ran the truck about a hour and turned it back on it ran all night no problem my truck had sat for over 24 hours and hadn't been started and the apu ran for about 10 hours the first part of that so I'm guessing it was just drained
  10. WitchingHour
    3,424
    2,144
    Apr 1, 2011
    Broomfield, CO
    You shouldn't be losing prime in the APU fuel system in that time.
