APU space
Discussion in 'Freightliner Forum' started by redlinesecured, Jun 29, 2018.
  1. redlinesecured
    redlinesecured Bobtail Member
    5
    Jun 29, 2018
    I have a 2016 Cascadia with 150 gal. Diesel Tanks on both sides. I want to install a tripac Evolution APU but do not have the necessary space due to the fuel tank. Can I slide the RS fuel tank forward to make space? Will doing that affect the vehicle in any way? Or do I need to install a smaller fuel tank on the Passenger side of my truck? Any help with this is appreciated. I currently only have 16" of space and need 29". Thanks
  3. CoyoteExpress
    CoyoteExpress Medium Load Member
    367
    173
    Oct 29, 2014
    Carlingford NB Canada
    It will move the fuelweight a bit to the steer axle
    A nice generator with 3500w/4500w peek
    https://www.walmart.ca/en/ip/firman...YonRVWbxFIZl0zfrZZQthpxStTVls_SEaAstbEALw_wcB
    A batt charger
    Then
    10,000 BTU Portable Air Conditioner with Remote
    And
    I think you'll like Air Parking Heater 5KW 12V No Noise Set Defroster Automatic Control Winter Supply with Free Silencer Control Switch for Home Bus Car Truck Boat Van Motor. Add it to your wishlist!
    Wish | Air Parking Heater 5KW 12V No Noise Set Defroster Automatic Control Winter Supply with Free Silencer Control Switch for Home Bus Car Truck Boat Van Motor
    So less then 2000$ cad
  4. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,292
    Sep 12, 2017
    Plymouth MI
    You have to have room somewhere under the truck without having to move a fuel tank. What is the wheel base of the truck and have you ran it up to Thermo King to let them have a look? On my Volvos I always had them mount the units under the passenger seat area, behind the removable skirt.
  5. redlinesecured
    5
    Jun 29, 2018
    I have not taken it in. I only talked to them through the phone. Thank you both for replying. I'll take it in and look into the generator option. Thanks
  6. Justrucking2
    3,211
    4,292
    Sep 12, 2017
    Plymouth MI
    Look under the skirting, anywhere there is room they can put one. And if you are keeping the truck, I would just go with the TK unit. I have the new Evolution, installed in January of this year, it freezes and heats me out of the cab.
  7. CoyoteExpress
    367
    173
    Oct 29, 2014
    Works only on the old ones on the new ones there is the dpf mounted
    Tb0n3 and Justrucking2 Thank this.
  8. Justrucking2
    3,211
    4,292
    Sep 12, 2017
    Plymouth MI
    On the Volvo, got it.
  9. redlinesecured
    5
    Jun 29, 2018
    I had a TK on a 2013 Freightliner and I really liked it. There is room under the passenger side. I hope they can mount it there.
  10. Aces-N-Eights
    Aces-N-Eights Light Load Member
    135
    200
    Feb 21, 2018
    Mobile, AL
    Do some research here on the forums about people's opinions of having an APU. Most would go back to one with someone else paying for it. They are problematic (at best) and a PITA to get serviced (regardless of what websites and dealers say). I would def go the generator / batt tender / portable ac route. Much cheaper, much more reliable, and portable from truck to truck (if you are a company / lease driver). I am installing a split system a/c powered by a 3500 quiet run gen set that will backfeed my inverter to keep batteries charged. Still, all said and done, looking at $4000 (including getting a friend to vacuum and charge ac) which is 1/3 to 1/2 of what an APU can cost.
    CoyoteExpress Thanks this.
  11. redlinesecured
    5
    Jun 29, 2018
    that is a good price. I am currently looking at that option. I am not familiar with that type of set up but ill definately do some research. Thanks
