APU Weight exemptions
Discussion in 'Trucking Industry Regulations' started by Jorihe84, Mar 18, 2012.
  1. Jorihe84
    Jorihe84 Road Train Member
    2,763
    1,333
    Sep 1, 2010
    North Florida
    Currently having this debate with operations.
    What are the weight exemption allowances for? Gross weight or axle weight? And how much?
  3. Yatista
    Yatista Medium Load Member
    479
    206
    Jan 25, 2009
    Upstate New York
    The allowance is for gross weight, 400 pounds or the actual weight of the unit, as certified by the manufacturer in writing. The certification must be carried on the tractor and the unit must be operational. The exemption is for STAA routes only, not all states have adopted the exemption for local routes.
  4. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    210
    Jan 31, 2012
    Green Bay Wi
    exactly 12400 on the steers is what transam says
  5. Emulsified
    Emulsified Road Train Member
    3,663
    3,499
    May 6, 2010
    Dallas, TX
    Careful!
    Not to exceed the tire rating capacity.
    My tires are rated 6175 lbs. So the max I can carry is 12,350 on my steers.
    Also, not all scale weighmasters are familiar with the exemptions. Best to carry a copy of the reg exemptions with you so you can point it out if need be.
  6. Cranky Yankee
    15,317
    210
    Jan 31, 2012
    Green Bay Wi
    trans am highlights the section in the regs
  7. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    If they would spec trucks right, then there would be no need for exemption. The truck I recently ordered is coming in at almost 2000 lb less than my present truck. Aluminum axle housings and wide based alone save more weight than any APU would add.
    Meltom Thanks this.
  8. Jorihe84
    2,763
    1,333
    Sep 1, 2010
    North Florida
    Can someone post the actual regulation for reference
  9. rachi
    rachi Road Train Member
    4,246
    5,231
    Feb 25, 2010
    SoCal
    Cali doesn't allow 400 over for the apu, neither does Tenn.
  10. Cowpie1
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
  11. sevenmph
    sevenmph Road Train Member
    2,960
    14,806
    Jan 26, 2007
    Pinellas county Florida
    I find it ironic, two of the states that whine the most about diesel exhaust, won't give allowances for a unit that cuts diesel exhaust. :biggrin_25511: :biggrin_25524:
    bergy Thanks this.
