APU with possible inverter (2018 Volvo VNL 760)
Discussion in 'Questions From New Drivers' started by CoveringBases, Aug 3, 2018.
  1. CoveringBases
    CoveringBases Light Load Member
    103
    65
    Jul 8, 2016
    This might be a stupid question, but I'm going crazy trying to figure it out.
    For the record, I have never had an APU before, so I really don't know much about them.
    I was just assigned a truck that I was promised had both an APU and an inverter in it. It has an APU (that only works if the truck is not running), and one power outlet under the bed (the one usually in the closet is not present). I do not see any sort of inverter, and where the controls for the inverter usually are, is the control for the APU instead.
    I can't get the power outlet to work at all. I hit the reset button, I looked under the bed hatch to make sure it was connected, I followed the cord that was coming out of the electrical box on the backside of the outlet, and it went inside a big metal box that is screwed shut. I went outside and opened the hatch from the side, and it is closed off from that side too. I have no idea where the cord ends up. When the truck was off, I turned the APU on, and the outlet still wouldn't work.
    I called Penske, which is where my company got the truck from. The technician wasn't sure, but he suggested the outlet was wired straight into the battery. Is that a thing? And, if so, why even have an inverter if you can plug an outlet directly into the battery?
    I asked the guy who had this truck before me, and he wasn't sure, but he suggested the outlet might only work when the truck is on shore power. Which is even more inconvenient than not being able to use it while running.
    In any case, I need the outlet to work! Even if the truck is running! And especially if I don't have shore power! The whole point of my needing it was to make my own coffee during the last hour my co-driver is driving, so I'm ready to go when he's done. We can't always count on a truck stop being where we need it to be, nor do I ever wish to drink the dreck most truck stops call coffee! :eek: We also basically never have access to shore power.
    Anyway. Would someone please advise if they think there is hope for the outlet to work for me? And what I might do to it to make that happen?
    Thank you!
  3. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    is there a shore power plug on the outside of the truck
  4. tscottme
    tscottme Road Train Member
    My last 2 Freightliners had Thermoking TriPac APU mounted on the frame of the tractor between sleeper and drive tires. The inverter was mounted in the driver-side sidebox. After the truck master electrical switch, on floor beside driver seat, has been turned off you have to press the ON switch on the inverter. My inverter had the switch on the topside of the inverter toward the top and back of the inverter. The inverter also has buil-in circuit breakers. They look like the GFCI switches household bathroom or kitchen electrical outlets have. The switches are side-by-side between the two electrical outlets built into the inverter itself. The 2 switches are usually marked "test" and "reset". Look on every side of the inverter for it's main ON/Off switch. Make sure it's turned on. Also press the "reset" button/circuit breaker to make sure it's not tripped. My Freightliners have the power outlets bult-in to the inverter plus two AC power outlets near the floor of the sleeper by the passenger side cabinet. The AC power outlets are next to the two 12 volt power outlets also near the sleeper floor and next to the passenger-side cabinet. I also have 2 AC power outlets inside the passenger-side cabinet.
    Once I come back from my days off, turn on the truck's master electrical switch near the driver seat, turn on the inverter master ON switch, I will have AC/household power in the truck until I turn off the truck master electrical switch. If the truck engine is off and the APU is off the truck will turn off 12 volt outlets and then turn off AC outlets once battery level is low. Otherwise my AC outlets are always active.
    I've seen inverters mounted in the truck side boxes, on both sides. I've also seen inverters mounted behind the passenger side seat.
    Every APU I've ever seen or heard about only works while the truck engine is shut down.
  5. tscottme
    I can tell when my inverter is working because my AM radio is nothing but a hummmmmm, no matter what frequency or station I try to tune in. The FM and all other features work regardless of inverter operation. AM radio is blocked out by inverter noise in my truck. Can you tune in AM radio stations?
  6. CoveringBases
    103
    65
    Jul 8, 2016
    I actually don't see one! There is a plug for the engine heater, but I don't see another plug out there.
  7. CoveringBases
    103
    65
    Jul 8, 2016
    Hrm. That is an interesting observation. I noticed in my last truck, when I tried to plug my white noise machine and bluetooth adapter into the power with the inverter on, all I got was a humming too!
    Anyway. I just checked the AM stations, and they do play, but they have what sounds like a helicopter playing alongside them. Not sure if that's normal, or not, because I don't usually listen to the radio (AM or FM) in the truck, plus this is the first time I've been in this particular truck.
  8. CoveringBases
    103
    65
    Jul 8, 2016
    I appreciate all of the info, but I can't find an inverter anywhere. Only the outlet, which has an electrical box on the backside of it, and a cord coming out of it that travels back and hides behind something I cannot see. :(
  9. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    They should have the inverter tied into the batteries as opposed to only AC power when the APU is running. Some offer this to supply more power to run microwaves, but virtually every truck has a full-time inverter, regardless.
    There's a chance the outlet you see comes off the APU equipped with an AC generator. This will supply A LOT of power to run big microwaves. But again, there should be a standalone inverter w/ outlet somewhere, unless somebody took it out.
  10. Trucking in Tennessee
    Trucking in Tennessee Road Train Member
    3,740
    5,740
    Mar 19, 2018
    Nashville
    That is a plug for external (or shore power). Should be a plug in the outside under your side door flap with a cover.
  11. STexan
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    I have one of those but it’s for the engine block heat in sub zero cold.
