APU's vs opti-idle systems
Discussion in 'Questions From New Drivers' started by Vapor8, Jul 2, 2014.
  1. Vapor8
    Vapor8 Light Load Member
    87
    24
    Jun 26, 2014
    Dallas
    Do opti-idle systems keep the cabin temp cool at night or are you sweatin balls when its over 100 outside?
    DocWatson Thanks this.
  3. Ultra7
    Ultra7 Heavy Load Member
    779
    180
    Feb 21, 2011
    NE Ohio
    Personally I prefer an APU. Those battery pack systems just can't handle the heat. You will be idling the truck at some point or it will be starting itself up if it has the auto start feature. The heating portion isn't too bad though.
  4. RogerThat72
    RogerThat72 Road Train Member
    1,787
    994
    Jan 30, 2014
    APU some times at night I wake up to being to cold and turn it off. APU all the way but they're exapensive luckily all trucks have them at this company.
  5. tow614
    tow614 Road Train Member
    3,759
    4,630
    Mar 18, 2013
    There simply is no comparison between the two. The diesel powered apu is tops.
  6. 77fib77
    77fib77 Road Train Member
    10,490
    65,567
    Jul 7, 2010
    St Louis
    If you leave it gear, will it still start?
  7. 25(2)+2
    18,750
    45,476
    Sep 18, 2006
    the road less travelled
    Although I've never used Opti-idle(TM Detroit) or IKON(Cummins version) there are specific things you have to do to enable it the would stop it from starting in gear, actually the gearshift bumping around on a start-up has been known to disable the system.
    My truck sits enough while I'm home that it's cheaper to idle when I'm with it, I guess.
  8. Brandson
    Brandson Medium Load Member
    667
    481
    Dec 14, 2013
    I've got a battery powered hvac. I don't know why everyone doesn't have them. If you have the ac on high, the truck might start itself once through the night. Depends on what else your doing with your battery too. Would probably suck without an auto start tho, lol.
    Stuka Thanks this.
  9. Vapor8
    87
    24
    Jun 26, 2014
    Dallas
    I
    I
    This
