**Chick Question, no laughing**
Need to know if when the brakes lock on a newer Peterbuilt if that is normal or not normal..?
Why would they lock up?
Thanks so much!
Are locking brakes normal on a Peterbuilt??
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Rockabecka, May 22, 2018.
Too much pressure on the pedal?
No that’s not normal. Maybe you have a sensitive foot valve and applying too much pressure. My 379 requires you to put a good amount of force to lock up. And by the way, if your lucky enough to be driving a peterbilt, please spell it right brotha
Bean Jr. Thanks this. -
Is she so old before ABS era?
Leaky s-cam seal letting grease onto brakes?
Can make things a bit grabby. -
Cam roll over.
The possibilities are endless depending on what you have and the conditions while operating and the condition of the truck. If your feeling something, get it in and get it checked out. If it's a normal condition, you will find out in the end. A good loaded road test with a qualified mechanic following by a visual brake inspection will usually find the issue in short order, if you can duplicate the concern.
