Are log books with no DVIR legal to use?
Discussion in 'Trucking Industry Regulations' started by Semi Crazy, Dec 30, 2013.
  1. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,045
    May 13, 2011
    Middle Tennessee
    I found a deal on loose leaf log books. The product is JJK 8542. They have no DVIR as far as I can see. It might be on the back but there's no pic of the back and no mention of it.
    My guess is they are OK, after all JJ Keller makes 'em that way. Just never used one with no DVIR in all my years.
    Anyway the deal is $.16/100 at ryderfleetproducts dot com.
    The only good thing about ELDs is everyone is liquidating the paper logs.
    Edit: When I went to buy them they are $16/100 in the cart. They tricked me!
  3. MJ1657
    MJ1657 Road Train Member
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    I use them. I have a separate homemade inspection sheet that I use.
    crb and Semi Crazy Thank this.
  4. 25(2)+2
    18,750
    45,481
    Sep 18, 2006
    the road less travelled
    We use inspection books, which substitute for the dvir included on the logs, The carbonless didn't work as well and was messier with the few I used that went both ways, and tearing out the carbon to use it the other way was something I have never had to do as we have been using the books since 2006. It's been so long since I used loose leaf at another company that I can't remember if we had carbons or dvir there or not.
    Keller prints those books with the company info pre-printed on them, too.
    On edit, we use 8542 logs, too, pre-printed with company name and main office address.
  5. commontrack
    commontrack Bobtail Member
    47
    22
    Aug 25, 2013
    Reno, NV
    Yes you can use the logbook without DVIR as long as you have a seperate DVIR book.
    gpsman Thanks this.
  6. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Though not very professional you can make a DVIR on a napkin if you so chose. You could take them logs and hand write on the back just as long as it covers the above info. But a separate DVIR book looks better and it's easier to use.
  7. Grumppy
    3,087
    10,583
    Dec 11, 2010
    West Monroe, La
    As stated above yes, you can have a separate log & DVIR.
    Some companies choose them because if a company only has one truck, they are not required to have a DVIR. Only companies with two or more trucks are required to fill out a DVIR for each truck. (If I am wrong, I welcome your correction)
  8. KW Cajun
    KW Cajun Road Train Member
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    True Grumpy, but with some restrictions.
    The company/carrier is limited to one trailer (or one doubles/triples set) for the DVIR exemption, otherwise they have to fill out a daily DVIR.
    Grumppy Thanks this.
  9. Semi Crazy
    3,033
    2,045
    May 13, 2011
    Middle Tennessee
    Well I ordered 15 of the 31 day log books and a DVIR book since that new law requires a DVIR only if there is a defect.
    The loose leafs were more expensive.
  10. Raezzor
    Raezzor Quis custodiet ipsos custodes?
    1,412
    1,186
    Aug 1, 2009
    Columbus, OH
    As far as I'm aware there that law about only requiring a DVIR if there were defects hasn't been written yet only discussed.
