Are Super 10's weak?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Wildcat74, Dec 20, 2011.
  1. Wildcat74
    Wildcat74 Medium Load Member
    354
    128
    Jul 15, 2008
    Omaha, NE
    So I've seen it alluded to in other threads but what's the honest truth? Are Super 10 transmissions less sturdily built?
  3. Hammer166
    7,458
    27,031
    Aug 18, 2007
    ~8600+' and loving it!
    No. Structurally, they are the same as a 13/18. Yes, they're missing two gears in the main box, and they do the range shift based on lever position; but there is no inherent weakness in the transmission.
    The problem with Super 10s is that if you allow the shifter to leave the right gate, the transmission attempts to shift to low range. Not a problem at any appropriate low range speed; however, if it's done at too high a road speed, it will fubar the synchro on the range shift. Just make sure you have geared down to at least sixth before kicking the lever to neutral when stopping.
    I haven't driven anything newer than '99 Super 10s, so they may have rigged up some sort of interlock on the newer models, but I know that was the issue with the early models.
    osokusmc and Wildcat74 Thank this.
  4. rollin coal
    rollin coal Road Train Member
    13,287
    26,798
    Mar 29, 2008
    TN
    I was once told either the input shaft or the output shaft (forget which) is a weak link with super 10's - no idea if it is true.
  5. JDP
    JDP Medium Load Member
    377
    404
    Sep 25, 2011
    Dubuque, IA
    We've ran super 10s on all our trucks for years, probably 200 trucks in total, never had a problem. Seems pretty bullet proof to me.
  6. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    a trans is only as good as the nut behind the steering wheel-nuff said.
    Ruthless Thanks this.
  7. Hammer166
    7,458
    27,031
    Aug 18, 2007
    Every one that failed where I worked had been driven by a driver who thought it reasonable to kick the tranny into neutral ~40mph coming down ramps or up to redlights. The trucks he never drove where all still going strong after 500K plus.
  8. rollin coal
    13,287
    26,798
    Mar 29, 2008
    TN
    So is that what stresses one and makes them break?
  9. Hammer166
    7,458
    27,031
    Aug 18, 2007
    Yep! The mechanic told us it screws the synchro (spits the pins, or something like that,) and exactly what had caused it. He said normally they hung in high range ( as ours had) when they finally let loose. He actually told us what he'd find before the trans ever hit the floor, and he was right. Basically the same as if you took a 13/18 and range shifted it at high speed multiple times; it would fail the same way.
    rollin coal Thanks this.
  10. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    over 1.4 mil miles on my super 10 never touched. original clutch went to 1.2 million miles
  11. Wildcat74
    354
    128
    Jul 15, 2008
    Omaha, NE
    Good to hear it all, this makes me a little leas scared to consider trucks with super 10's. Seems to be a lot of them popping up around me lately.
