are the Prostar's Heavier than The KW
Discussion in 'Questions From New Drivers' started by TrucKer 999 TriLLion, Nov 23, 2011.
  1. TrucKer 999 TriLLion
    TrucKer 999 TriLLion Light Load Member
    223
    28
    Mar 7, 2010
    Ca
    are the International Prostars heavier than the Kenworth T660's or the W900's ????.....
    i already heard drivers say their heavier than The Peterbilts.....
  3. celticwolf
    celticwolf Road Train Member
    1,527
    642
    Oct 10, 2010
    Kittrell, NC
    I don't know, but with the chains hangin and me in it my Prostar is at 20,900.
  4. lv gn
    lv gn Heavy Load Member
    985
    469
    Jun 23, 2008
    las vegas nv.
    my 2011 prostar with big sleeper,maxxforce engine,275 gal.fuel and a PTO and air compresser is 19,700
  5. fortycalglock
    fortycalglock Road Train Member
    6,155
    6,583
    Jun 25, 2011
    Tourist Town, FL
    The make and model of a truck have little to do with how much it weighs, it's based mainly on how the truck was spec'ed. A lot of new drivers and even some old ones don't realize trucks are completely custom vehicles, compared to say your typical Mustang. A double frame Prostar set up for heavy haul will easily outweigh a Pete 389 in a standard haul configuration. I hear it all the time with my Western Star, "Man those trucks are heavy" Sure if you talking about a logging Western Star set up to haul 150,000 lbs. Mine, full of fuel, rack and chains weighs in at 20,000 lbs. I drove a 51" sleeper Int 9400 with a double frame that weighed 21,500 without a rack or anything.
    Panhandle flash Thanks this.
  6. chompi
    chompi Road Train Member
    5,653
    3,485
    Jun 21, 2008
    Deland, FL
    I doubt they are heavier then the W900. Maybe someone could post weight specs.
  7. chompi
    5,653
    3,485
    Jun 21, 2008
    Deland, FL
  8. American-Trucker
    American-Trucker Road Train Member
    10,371
    5,085
    Nov 8, 2009
    Charlotte, North Carolina
    :biggrin_2551: Thats some heavy plastic!:yes2557:
    My Century full of fuel, with me in it, chains, a big tool box, and a sleeper full of stuff is only 17,500lbs!
    American Trucker
  9. cowboy_tech
    cowboy_tech Road Train Member
    2,290
    1,092
    Sep 27, 2008
    Avondale, CO
    My Columbia with house rack, pumps and 3/4 tank of fuel weighs in at 19,800.
    Sent from my ADR6400L using Tapatalk
  10. BretStep
    BretStep Light Load Member
    168
    32
    Sep 27, 2011
    You have to compare apples to apples and make sure they are spec'ed the exact same, right down to the same name brand axles, tires engine, trans, ect. Otherwise the data is useless.
    Typically the newer aero trucks weigh less as they make use of more plastic and composite materials.
    Your question should be directed to a new truck dealer and make sure they give you a detailed sheet that backs up the numbers.
    volvodriver01 Thanks this.
  11. American-Trucker
    10,371
    5,085
    Nov 8, 2009
    no, newer truck = more weight for the EPA crap they've added allot of weight with this Regen/def crap.
    Good luck with a dealer knowing there a$5 from there elbow! I asked Peterbilt the differance in weight between a 386 and a 389 with identical specs i even gave him the specs i wanted and he couldnt even come up with a ballpark figure on weight, but he sure could give me a price though...
    American Trucker
