are these soot levels really bad oil analysis
Discussion in 'Questions From New Drivers' started by kay_ray, Sep 5, 2019.
  1. kay_ray
    kay_ray Medium Load Member
    486
    1,206
    Jun 6, 2019
    hey i am looking at this fleet maintained truck and the dealer did the oil sampling before they bought the truck.can you guys see anything abnormal .its a cummins isx15 2016 450 hp .any help will be appreciated.
  3. kay_ray
    486
    1,206
    Jun 6, 2019
    and the truck have around 300000 miles on it
  4. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Couple things I would recommend if you buy this truck. First have the overhead ran, then get a Diesel Force Cleaning. Then use Max Milage fuel additive from Pittsburgh Power to keep that engine and EGR system clean. I have done all these on mine and still running great with 642k on it. I have an ex-werner T680. That Diesel force cleaning will get the entire engine internals and filter system clean.
    FlaSwampRat and kay_ray Thank this.
  5. kay_ray
    486
    1,206
    Jun 6, 2019
    will do so heard alot of good things about that diesel force cleaning .did you see anything alarming in the oil sample report ?. thanks
  6. tnevin225
    1,166
    1,601
    Jan 1, 2014
    No Kay Ray I just had mine done and didn't have an oil sample on I'm not quite sure about the soot number on a cat sample, I use OPS and my soot is usually at >1. How are the rest of the specs on the truck?
    kay_ray Thanks this.
  7. kay_ray
    486
    1,206
    Jun 6, 2019
    everything els is pretty good around 90%rubber on michelin low pros90 percent brakes truck was never idled much because of apu,no warranty work done,rears are 2.64 with 10 speed auto .
    ecm report was pretty good gave around 7.8 mpg average . no major fault codes have 9 months of original factory warranty left and 1 year of red oval .passed dot with flying colours .
  8. tnevin225
    1,166
    1,601
    Jan 1, 2014
    Sounds good, good luck. I gotta get back to work.
  9. Lazer
    Lazer Road Train Member
    1,792
    2,851
    Jan 22, 2017
    sounded good, except for the auto.is an automatic, or auto-shift? if auto-shift for $1500.00 to $2000.00 you could change it to a manual.
