Are we allowed to fuel up at any pilot flying j?
Discussion in 'Schneider' started by DAX_, Mar 6, 2019.
  1. DAX_
    DAX_ Medium Load Member
    603
    502
    Sep 4, 2017
    or does it have to be authorized first.
    Im new here thanks
  3. mickeyrat
    mickeyrat Road Train Member
    7,859
    7,542
    Nov 24, 2011
    on my 30 min break
    yes but it will ding you on bonus metrics I believe.
    @gentleroger can confirm.
    gentleroger Thanks this.
  4. LtlAnonymous
    6,084
    21,041
    Dec 23, 2016
    They didn't allow fueling at Flying J's when I was there years ago, but that was before all the truck stop mergers.
  5. Asphalt Anarchy
    Asphalt Anarchy Light Load Member
    93
    67
    Dec 4, 2014
    Atlanta, Ga
    PFJ is preferred over the others but anything not on your automatic fuel plan shows up in your metrics. I haven't had my bonus dinged over it. The only thing I haven't done at Schneider is OTR Van so if that's what you're doing I don't know. My original TE would only stop at Loves for the last 15 years he said. You're not getting in trouble over it either way.
  6. gentleroger
    gentleroger Road Train Member
    7,509
    20,409
    Jun 1, 2010
    It is your responsibility to not run out of fuel, so your efs card will work at any PFJ, any Loves, any Kwik Trip, and any Road Ranger. If you need to fuel out of network, you will need to call in to ops and get a one time fueling authorized. In 8 years I've only needed to twice, so not a common thing.
    All that said you want to follow the fuel solution whenever possible. Once you make a load ative, work flow will ask your fuel level, then update the dispatch in navigo. You are excepted to follow the fuel solution 85% of the time.
    If you skip a fuel stop, it doesn't hurt you provided you do not fuel somewhere else. Fueling at an oc doesn't count for or against you. Up to three times per load you can request a new fuel solution thru work flow. However you need to be at least 100 miles (or 3 hours) from the last request to get anything different. I usually try and wait until the following morning.
    Njhandofdoom Thanks this.
  7. mickeyrat
    7,859
    7,542
    Nov 24, 2011
    on my 30 min break
    road ranger still a fuel spot since they split with pfj?
  8. gentleroger
    7,509
    20,409
    Jun 1, 2010
    Yep, I think pilot still owns them, but they are a distinct brand now. The pfj rewards card no longer works. It is a flaming pain.
  9. drvrtech77
    drvrtech77 Road Train Member
    14,496
    140,231
    Mar 20, 2010
    The road ranger is not owned by pilot they had an agreement to sell pilot branded fuel and accept the rewards program but pilot was trying to stiff the road ranger so the road ranger cancel the agreement...
    Farmerbob1, gentleroger and bzinger Thank this.
