ARKANSAS DOT almost put me out of service
Discussion in 'Ask An Owner Operator' started by henboy1, Dec 22, 2019.
  1. henboy1
    henboy1 Medium Load Member
    332
    139
    Mar 26, 2011
    stockbridge
    All we hear about are people posting their passed level one inspections but no one post about the mishaps.Here we go...
    As most of you know , I just switched over from Flats to dry van with the 2003 Wabash I recently bought.Coming from Tulsa on 40, I just passed a roadside DOT on the shoulder.He pulls out and follows me.As we get closer to the rest area, he puts on his lights.I pull into the rest area.He opens the passenger door and said, "you did nothing wrong , but you just weaved a little bit and wanted to make sure you were alright".In my mind, muther######, I wasnt sleepy.He looked deep into my eyes and asked about my picks and deliveries and sent me on my way.5 miles down the road, my prepass didnt alert me , so I know they turned off their device at the coop.I pulled in , and got a green light to come on the scaled.Jumped on the scale with 10kibs in the box.Stood on the scale for a while and he microphoned me to come out back while everyone bypassed .Checked my paper work and logs.He really went through my phone logs and found nothing.Told me to meet him by my truck with the creeper.I stood a few feet from the truck as he instructed, and went inside the truck and checked the sleeper.He then broke the seal and looked in the box.He then issue me their own seal and asked me to close the doors.
    He creeped under the truck and trailer.Checking lights, the #### headlight didnt wanna work.That was perplexing , because it worked during pretrip.Marker lights work but not the headlight or truck tail.He gave me a warning for 2 trailer slacks being out of adjustment and the tail lights on the truck didnt work.WARNING WITH NO FINE........same #### as an actual ticket smh
    I then spent 10 minutes in the parking lot figuring out my lighting issue.I checked the fuse,the relay and everything seem fine.I then hit the flasher light and turned the headlight back on , and everything started working.Of course I couldnt go back to the officer to change the warning report.Having automatic slacks never gave me a hint to check my brake during pretrip.I got my creeper out with my 12mm ratchet and grease gun.Greased all slacks and adjusted them.To end this long story, he said I was 2 1/4 inch and 2 1/2 out of adjustment on both axles and that was close to being put out of service.smh
    lesson learned to keep my eye on even automatic slacks.
    Reason for edit: Skirting profanity filter
  3. AModelCat
    161,332
    2-1/4" and 2-1/2"? With standard stroke chambers you would have had no brakes on one and a little bit of heat would have over-stroked the other one. Keep an eye on those 2 slacks. If they go out of adjustment again, make sure your pushrods are cut the right length and consider replacing the slacks if the rods are the right lengths.
    EverLuc, Wheeljack, Dino soar and 3 others Thank this.
  4. henboy1
    332
    139
    Mar 26, 2011
    stockbridge
    Good info.Thx
  5. PE_T
    PE_T Road Train Member
    It is what it is. I know many drivers never check their equipment, but independent o/o’s need to make sure more than anyone else that all their lights are working, brakes adjusted properly, no leaks, and so on. Whenever a cop sees an independent passing through, they know they can bust them. Mega companies have trucks less than 3 years old and a group of lawyers to check if any citations their drivers were given can be fought.
    Rideandrepair, Chubby Fly and henboy1 Thank this.
  6. Chubby Fly
    Chubby Fly Medium Load Member
    569
    797
    Nov 25, 2019
    Automatic slack adjusters never need adjustment unless they are wore out and if your cam bushings are shot. I replace them all in one shot once one of them starts going. They last many years with routine greasing. If you have to adjust them, it’s time to replace. Good ones cost 80 bucks. If s cams bushings are shot, the automatic adjusters will go out of adjustment within just a few stabs of the brakes. And also, takes 1/2 hour to swap out a slack adjuster
  7. Mattmanstroked
    Mattmanstroked Light Load Member
    185
    279
    Nov 24, 2019
    Where in Arkansas?
    Weigh station at about exit 275 may or may not trip my drivewyze.
  8. henboy1
    332
    139
    Mar 26, 2011
    stockbridge
    I will definitely know in a few days. Now that they are adjusted, I will keep an eye to see if they go out again
    Rideandrepair and Chubby Fly Thank this.
  9. henboy1
    332
    139
    Mar 26, 2011
    stockbridge
    I am thinking the switch was corroded.Was working when I did PTI that morning.Came back on when I played with it, but you are right about the check ups
    PE_T Thanks this.
  10. Long FLD
    Long FLD Road Train Member
    12,487
    51,836
    Mar 4, 2015
    Every once in a while when you’re sitting at a red light or something really stomp on your brake pedal. That will ratchet your auto slacks up.
  11. henboy1
    332
    139
    Mar 26, 2011
    stockbridge
    Crawford County scale house on 40. Crawford , AR.I think the road side inspection radio'd the scale house to bring me in.
    Rideandrepair, PE_T and Mattmanstroked Thank this.
  12. henboy1
    332
    139
    Mar 26, 2011
    stockbridge
    True!
    bzinger Thanks this.
