armrest swap
Discussion in 'International Forum' started by Shadowhawk01, Jul 9, 2013.
  1. Shadowhawk01
    Shadowhawk01 Bobtail Member
    39
    8
    Aug 28, 2012
    I Have A 06 9400I That I Just Started Driving For My Company. EverythinNg On It Works Great Except For The Icon System Dosn Work So Yhe Engine Wont Idle Longer Than 5 minutes But Hopfully That Will Be Fixed Soon. My Question Is My Right Armrest on The Drivers Seat Will Not Lock INto Position.Cuz The Locking Gear Is Stripped Out. Im AssumIng I Can SwapThe Passenger Seat Armrest With The Drivers SeAt Since They Ar Identicle. Only Problem Is I.cant Figure Out How To Pull The Armrest Off. Can Anybody Help Me Out With This? SOrry Fo All The Typo's... My Phone Dosnt Want To Cooperate For Some Reason.
  3. Heavyd
    Heavyd Road Train Member
    7,752
    6,186
    Feb 4, 2009
    I can't remember exactly, (it also depends on the model of seat), but I am thinking you undo the zipper, pull back the covering to expose the joint and there is a spring clip that holds it on.
  4. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,161
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    Make of seat would help.
    On most, there is a zipper by the armrest.
    Undo the zipper, and then push the armrest into the seat, this will allow you to pull the clip out and remove the armrest.
    I have fixed the ratcheting type by screwing in a self drilling screw/bolt where I want it to stop, and that has worked.
    Martin
  5. Shadowhawk01
    39
    8
    Aug 28, 2012
    the Only Identifying Mark I Have Been Able To Find On These Seats Is "National" On The Seat Back Adjustment Knob. There Is No Zipper Near The Armrest . I Try Pushing In The Vinyl Around The Post For The Armrest But I Don't SeeHow Its Attached.
  6. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
    There's a seam between the armrest and seatback it's held together with Velcro. It should come off that way.
  7. Shadowhawk01
    39
    8
    Aug 28, 2012
    Ah Ok Thanks For The Help. I Was Able To Get The Padding Off And Expose The Inner Workings Of The Armrest But Im Kind Of.lost.As To How It Comes Off. Does It Come Off At The Armrest Itself Or InsiDe The Seat?
  8. EZ Money
    EZ Money Road Train Member
    It may be just as easy to swap seats. Usually 4 bolts under the seat cushion that holds it to the base.
  9. Shadowhawk01
    39
    8
    Aug 28, 2012
    Hmm Its That Tough Huh? You Would Think For A Part That Would More Likely Not LasT As Long As Th Seat Itself They Would Make It Easier To Change Out.
  10. Heavyd
    7,752
    6,186
    Feb 4, 2009
  11. Shadowhawk01
    39
    8
    Aug 28, 2012
    Awesome! Thanks A Lot That Helpe A Ton...Got The Armrests Swapped Out Easy A Can Be In About 5 Min. I Love Forums Like These... Always Somebody Out There That Has An Answer Or A Direction To Point Those That Need A Littlehelp.
    Heavyd Thanks this.
