as a *specialized car hauler what is the max width of my bed
Discussion in 'Flatbed Trucking Forum' started by TowHaul, Feb 20, 2018.
  1. TowHaul
    TowHaul Medium Load Member
    416
    79
    Mar 7, 2016
    I am having a bed lift built. the bed itself is 102", however the lift cylinders will extend 3" on each side for a total of 108". I haul rv campers and cars in a specialized truck. What is my max legal width in this scenario?
  3. Blackshack46
    Blackshack46 Road Train Member
    LGarrison Thanks this.
  4. TowHaul
    416
    79
    Mar 7, 2016
    I am told by others in the specialized auto carrier field we can go 108" over but no more, 3" on each side. Truck bed is being built right now and the trailer builder is forced to put the lift cylinders 3" over on each side below the bed.... bed measures 102"
  5. Gunner75
    Gunner75 Road Train Member
    5,701
    9,075
    Mar 17, 2014
    Jackson Center Ohio
    So go ask in the car hauler forum.
    Blackshack46 Thanks this.
  6. Gunner75
    5,701
    9,075
    Mar 17, 2014
    Jackson Center Ohio
    I can tell you though, 102 is the maximum allowed.
  7. TowHaul
    416
    79
    Mar 7, 2016
    Appendix D to Part 658 - Devices That Are Excluded From Measurement of the Length or Width of a Commercial Motor Vehicle
    The following devices are excluded from measurement of the length or width of a commercial motor vehicle, as long as they do not carry property and do not exceed the dimensional limitations included in § 658.16. This list is not exhaustive.
  8. TowHaul
    416
    79
    Mar 7, 2016
    then you have not done your homework if you think that blanket statement is a answer to my complex question.
  9. Gunner75
    5,701
    9,075
    Mar 17, 2014
    Jackson Center Ohio
    Well you seem like you think you're on top of it, so why you asking?
    kylefitzy and Blackshack46 Thank this.
  10. TowHaul
    416
    79
    Mar 7, 2016
    3. Devices excluded from width determination, not to exceed 3 inches from the side of the vehicle including, but not limited to, the following:
    (a) Corner caps;
    (b) Hazardous materials placards and holders;
    (c) Lift pads for trailer on flatcar (piggyback) operation;
    (d) Rain gutters;
    (e) Rear and side door hinges and their protective hardware;
    (f) Side marker lamps;
    (g) Structural reinforcement for side doors or intermodal operation (limited to 1 inch from the side within the 3 inch maximum extension);
    (h) Tarping systems for open-top trailers;
    (i) Movable devices to enclose the cargo area of flatbed semitrailers or trailers, usually called tarping systems, where no component part of the system extends more than 3 inches from the sides or back of the vehicle when the vehicle is in operation. This exclusion applies to all component parts of tarping systems, including the transverse structure at the front of the vehicle to which the sliding walls and roof of the tarp mechanism are attached, provided the structure is not also intended or designed to comply with 49 CFR 393.106, which requires a headerboard strong enough to prevent cargo from penetrating or crushing the cab; the transverse structure may be up to 108 inches wide if properly centered so that neither side extends more than 3 inches beyond the structural edge of the vehicle. Also excluded from measurement are side rails running the length of the vehicle and rear doors, provided the only function of the latter, like that of the transverse structure at the front of the vehicle, is to seal the cargo area and anchor the sliding walls and roof. On the other hand, a headerboard designed to comply with 49 CFR 393.106 is load bearing and thus limited to 102 inches in width. However, the “wings” designed to close the gap between such a headerboard and the movable walls and roof of a tarping system are width exclusive, provided they are add-on pieces designed to bear only the load of the tarping system itself and are not integral parts of the load-bearing headerboard structure;
    (j) Tie-down assembly on platform trailers;
    (k) Wall variation from true flat; and
    (l) Weevil pins and sockets on low-bed trailers.
    [ 67 FR 15110, Mar. 29, 2002]
  11. TowHaul
    416
    79
    Mar 7, 2016
    You do realize this question is well over your head, actually based on your replies you likely dont. Just posted several examples where the truck can be OVER 102"...whoaaa MIND BLOWN huh?
    *just found the ignore link, so i have no clue his response and honestly dont care.
