Ok here goes..... bought a used Uniden pc78xlw. It worked when I bought because I saw it and talked on it and heard replies. Bring it home and put in my Dodge Ram. Instal a Tram 4-B-HC 4ft fiberglass antenna on the truck bed behind cab. Also I installed an external speaker in the cab. Can not get the SWR's right. So I stop and slap on a magnetic roof mount about 30 in tall. I can cal the SWR'S to about 1.2 2.0. BUT I have no sound from anything. Not from weather channel, squelch, NOTHING. Adj all knobs but no good. Also I can hear myself thru the ext speaker. Do i call it quits and buy a whole new setup or does anyone have a clue. Radio is wired to battery, ant grounded thru the mount with sheet metal screws. What gives???
AT my wits end.
Discussion in 'CB Radio Forum' started by bigbotes, May 17, 2015.
Page 1 of 3
You screwed the mag mount to the cab??
Check where your ext. spkr is plugged in at. Right behind the cab is not optimal. About 18" - 24" will work better unless your truck is like mine and has a poor rf ground on the bed. I ended up drilling a hole in the roof of the cab. What the heck, it's a pickup and won't hurt the value at all when you trade it in......as long as you put one of those rubber plugs in the hole so it won't leak!
Bout Z Thanks this. -
I must be confused mike lol, he said he first used a fiberglass whip behind the cab, which is not optimal as you said. Then he changed to a mag mount, but never said he switched back. Does sound like ground issues though.Last edited: May 17, 2015
update........ when I used the 30 in magnet mount on the roof and did nothing else, I got good weather channels and heard a few people but it sounds good for a few sec then their voice slowly dies away.
So..with the mag antenna hooked up, you turn the radio on, have recieve, and weather, then it slowly fades out after a few seconds? Turn the radio off, then back on, and the same thing? What about transmit, does it work in this pattern also? Or can you tell?
I tried sending a few times but no reply. And yes, turn off then on and same thing. I'm pretty new to this so bare with me. Last time I had a cb was in the mid 80's and then I just wired it up, slapped a magnet antenna to the roof and was in business all day long.
No the original fiberglass one has the mount screwed to the bed.Bout Z Thanks this.
Could be a couple different things. A short in the coax or in the mag mount. A short in the mic. Could be a bad component or cold solder joint in the radio. Its just hard to say from here. Are your antennas and coax new, or known to be good?
If so, first thing I would do, try a different mic.
Second...You could try moving your tram antenna and mount towards the rear of the bed and see if there is any improvement. Antennas don't like any vertical metal any where near them, that's why mounting directly behind the cab is not the best place to mount one. Some guys do, and can achieve decent swr, but performance suffers greatly compared to other mounting locations. You want your antenna up as high, and as far away from any obstructions, as you can possibly get it. -
He might be better off just taking the whole setup to a good CB shop and have it checked out.
Page 1 of 3
