Audio install 05 VNL questions
Discussion in 'Volvo Forum' started by RubyEagle, Feb 1, 2015.
  1. RubyEagle
    RubyEagle Medium Load Member
    632
    790
    Apr 17, 2010
    Hi all thanks for the great forum. I have read here that a Blaupunkt cd player is plug and play install in place of the factory cassette radio. I bought a double din Pioneer FH_X700 cd radio and had a couple of questions.
    Will this radio work with this truck? Anyone running a radio similar? Will l need any adapters to install this? Or is it just a standard radio install as in just pull the factory unit and bottom under radio storage plate and mount new unit? I have only worked with cars so just need to know if l will need anything special to get it done. Thanks.
  3. fortycalglock
    fortycalglock Road Train Member
    6,156
    6,586
    Jun 25, 2011
    Tourist Town, FL
    All you should need is the adapter harness, just like in cars. A little googlefu will tell you which one, or crutchfield might as well.
  4. Zusky407
    Zusky407 Bobtail Member
    32
    Jul 29, 2014
    Nebraska
    i believe a harness from 96-02 vw audi will work
  5. RubyEagle
    632
    790
    Apr 17, 2010
    Yeah we used a leftover Volvo to Panasonic harness we had. Had to cut off the connector and match wires manually. Thanks for the help!
