Authority name
Discussion in 'Ask An Owner Operator' started by Pup97, Oct 20, 2021.
  1. Pup97
    Pup97 Light Load Member
    191
    263
    May 30, 2016
    So I have a llc and ein under one name. I want to start my authority process under a different name. So do I have to change llc and ein name to match the authority name? Anyone have llc and ein under different name then the authority name?
  3. Midwest Trucker
    5,896
    21,282
    Aug 31, 2018
    You just do a dba. Its fairly common. If you don't want to do a dba for your authority then you'll have to change it.
    Bean Jr., Rideandrepair and SteveScott Thank this.
  4. Pup97
    191
    263
    May 30, 2016
    So do I have to mark anything dba or just use the name I want when filing for the authority?
  5. Midwest Trucker
    5,896
    21,282
    Aug 31, 2018
    You’ll put your company name and then mark the dba and put that name. It’s been 13 or 14 yrs since I’ve done it though. I see it frequently so know it’s possible. People WILL be able to see the company name though if they look up your mc number.
  6. SteveScott
    SteveScott Road Train Member
    4,897
    16,806
    Nov 10, 2015
    I believe the authority has to be under the same name as your LLC, but you can operate under the dba. You can just put the dba name on your truck and you don't need to list the LLC name with it unless you want to. Been a while for me too, but I believe you list your dba on your corporate articles as well.
  7. Ridgeline
    22,401
    116,508
    Why do you want it under different names?
