Auto Shift Transmissions
Discussion in 'Ask An Owner Operator' started by FredW, Jul 17, 2014.
  1. FredW
    FredW Light Load Member
    59
    Warrenton, VA
    Hi All,
    I am curious if anyone would relay their experience with autoshift transmissions.
    We are considering purchase of a new Freightliner with and Allison or Fuller autoshift transmission. Is there any advantage to either? Has anyone done a cost analysis to know at what point the fuel savings offset the extra cost of purchase?
    The truck would be used on the DelMarVa penninsula so the terrain is very flat. It would be used on relatively short trips with several stops per day.
    Any input would be most appreciated. As far as which one to pick, is either more reliable and how is the support from the manufacturers should there be a problem?
    Thanks in advance,
    Fred
  3. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Is it a tractor trailer or straight truck you will buy?
    And why disregard the Detroit transmission?
    FredW Thanks this.
  4. mp4694330
    mp4694330 Road Train Member
    1,529
    1,459
    Aug 30, 2010
    Chicagoland
    If TT, is it class 8?
    FredW Thanks this.
  5. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    search the forum. There are tons of threads about the benefits of manual vs auto. They both have strengths. If i was buying a truck for me to drive id get an auto, but I think i could attract drivers easier with an auto. As for cost, I dont think there is a huge difference. Doing on flats should make any trans last a little longer.
    I would however buy the detroit trans if i was buying a new truck. The detroit trans has lots of cool tech that will get that extra bit of mpg.
    FredW Thanks this.
  6. BigBadBill
    BigBadBill Bullishly Optimistic
    4,599
    4,439
    Oct 2, 2010
    Chattanooga, TN
    Everyone has learned a lot from what Volvo has been doing in Europe for over a decade and brought the us with the iShift. Reports over the past 4-5 years is showing very favorable results in both reliability and fuel economy.
    What version you get is going to depend on what your power is.
    FredW Thanks this.
  7. FredW
    59
    Warrenton, VA
    Hi,
    Thanks for you input. It is a Class 8 tractor trailer and would go out at 80,000 lbs. most of the time. We would consider the Detroit transmission as well.
    Thanks,
    Fred
  8. FredW
    59
    Warrenton, VA
    Hi,
    It is a Class 8 TT usually loaded to 80,000 lbs.
    Thanks,
    Fred
  9. FredW
    59
    Warrenton, VA
    Thanks so much for your reply. I greatly appreciate the info!
    All the best,
    Fred
  10. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Fred,if you are buying a Freightliner with the Detroit engine,i would buy it with the Detroit gearbox.
    That gearbox is fully integrated with the engine and the truck.
    Will also have the best working software as Mercedes works on this as a package.
    And you know the gearbox comes from a long line which they have had running in Europe for a very long time.
    FredW Thanks this.
  11. FredW
    59
    Warrenton, VA
    Hi,
    Thanks so much for the information and recommendation. I very much appreciate it.
    Fred
