Automated transmission on a downgrade
Discussion in 'Experienced Truckers' Advice' started by hpfranzen, Jan 25, 2012.
  1. hpfranzen
    hpfranzen Bobtail Member
    4
    Rheurdt
    Hi all,
    maybe this is more of a question for drivers than for technicians, but here goes:
    How do you handle the automated transmission on a downgrade where you would not want the automatic shift into a higher gear?
    I´m a newbee, appreciate advice.
    Smooth operations!
    HP
  3. Big Jay
    Big Jay Light Load Member
    176
    176
    Jul 31, 2011
    litchfield, mn
    Pick your gear before you crest, by manually shifting in the H position. Flip your Jake on and let it rumble.
  4. jlkklj777
    jlkklj777 20 Year Truckload Veteran
    1,871
    1,090
    Oct 1, 2007
    Duncannon, Pa
    Use the brake and engine brake to keep the road speed down. The automatic trans will not shift unless you let the tach go too high.
  5. jgremlin
    jgremlin Heavy Load Member
    867
    497
    Apr 21, 2010
    SW Michigan
    There aren't a ton of steep grades where I run. But I don't really do anything all that different in the auto than I did in a manual. My truck has an Eaton ultrashift with a push button controller. Once it downshifts, you can tap the manual button and it won't upshift unless you tell it to. But I never bother with that because Michigan is pretty flat. I don't see grades steep enough and/or long enough to warrant kicking into manual mode. I just slow down so it downshifts before the grade and then I use the jake and service brake as required to keep the speed in check. No muss no fuss.
    Automatics do grades just fine. Its really nothing to be concerned about.
  6. withit
    withit Light Load Member
    86
    41
    Jun 12, 2010
    SW MI
    I know this is off topic im wondering where you at in SW MI i live in the Battle Creek / Coldwater area.
  7. mustang970
    mustang970 Road Train Member
    1,844
    1,259
    Mar 27, 2009
    Homeless
    H is hold.
    you put yourself in the right gear, engage retarder, and like big jay said, let it rumble.
    You can shift up or down, skip gears, hold a selected gear
  8. kajidono
    kajidono Road Train Member
    6,422
    4,659
    Jun 1, 2009
    Streetrat
    Hold/manual, and if you need to slow down for something, low (or whatever they call it.) That low setting will continually downshift all the way down to the lowest gear as you slow down, assuming you have the jake on and are indeed slowing down.
  9. jgremlin
    867
    497
    Apr 21, 2010
    SW Michigan
    Vicksburg.
  10. Green Machine
    Green Machine Medium Load Member
    623
    175
    Jul 23, 2009
    That LOW setting is what I always used going down a steep grade.
