Automatic transmission in snow
Discussion in 'Experienced Truckers' Advice' started by JReding, Dec 4, 2016.
  1. JReding
    JReding Road Train Member
    1,955
    3,504
    Sep 8, 2014
    Puyallup, WA
    Okay, folks, my turn to sound like a noob...
    I was just assigned the first of our automatic trucks. '16 Cascadia daycab, DD13 motor, DT12 tranny. I have always driven a manual transmission until now.
    I'll be doing nightly round trips over Snoqualmie Pass once a week, starting this week. Recommended practice for snow conditions? Should I keep it in automatic mode? Switch to manual? I'm listening...
  3. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,058
    Nov 18, 2014
    Land of local
    Manual mode and jake off or on low at the most if your loaded heavy. I took an auto dt12 up to rochester ny 2 weeks ago during the snow storm with only 7k in the box and did just fine, little hairy at times but got there and back just fine.
    JReding Thanks this.
  4. witch_hazel
    witch_hazel Bobtail Member
    47
    85
    Nov 27, 2016
    I have 500000 miles on a DD15 with Mercedes 12 auto driven every hill on 80 from coast to coast
    use jake all the time sparingly in bad conditions
    and never put it in manual
    but maybe I don't know what I am doing
  5. JReding
    1,955
    3,504
    Sep 8, 2014
    Puyallup, WA
    I'll be pulling a 40 footer with the axles all the way to the rear with an average of 8,000-10,000.
  6. JReding
    1,955
    3,504
    Sep 8, 2014
    Puyallup, WA
    I forgot to ask; this is also assuming I'll be chained nearly every trip through the winter. Does that change anything ?
  7. Brettj3876
    11,257
    54,058
    Nov 18, 2014
    Land of local
    Those scare me in auto in bad conditions. I've only been driving less than 2 years but the dd15 and the auto with the jake on high would be an accident waiting to happen in some spots. I hardly use the jake in bad conditions and just take it at a safe speed with the power divider kicked in
  8. ExOTR
    ExOTR Windshield Chipper Extraordinaire
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    I would assume you would use manual mode in slippery conditions? Holding a gear at 20mph is better than it attempting to shift at a bad moment.
    JPenn, Chewy352 and JReding Thank this.
  9. JReding
    1,955
    3,504
    Sep 8, 2014
    Puyallup, WA
    That's my thinking as well, I just want to defer to those of you who have the experience I don't with the auto.
  10. striker
    striker Road Train Member
    6,023
    6,436
    Aug 8, 2009
    Denver, Co
    My exp. is with Mack's and either Eaton Fuller Autoshift or Mack Mdrive automatic transmission, gentle on the throttle, jakes on low or off, increase following distance, and take your time. I run I-70 and the Mtn's of Colorado with mine, almost 1.5 million miles on autoshifts, almost 200K on automatics.
    Manual mode is beneficial, but not always required, most of the time I run mine in auto mode and just play with the throttle, Manual mode on the down hill. Only time I use manual mode on the climb is very low traction situations where even with chains I start to spin.
    dunchues, illbback and JReding Thank this.
  11. Raezzor
    Raezzor Quis custodiet ipsos custodes?
    1,412
    1,186
    Aug 1, 2009
    Columbus, OH
    With the auto in auto I would never use the jakes. Those #### things love to downshift and hit 1800 rpm or more just for kicks and stopping power. In manual it might be ok if you know your truck and are confident in your traction, but in auto I'd think it'd be a bit too much of a crap shoot unless you REALLY know your trans and it's shift points.
