I'm just dreaming right now about having my own truck. Trying to get a list of what the different automatic transmissions are named for the sake of searching online for trucks for sale. I figure I'm at least 5 years from even considering buying something. I'm interested in auto's cause my left knee is fubar. No haters please![]()
Automatic Transmissions
Discussion in 'Trucks [ Eighteen Wheelers ]' started by OzzyOKC, Dec 8, 2013.
Since your left knee is bad I'm guessing you want one without a clutch pedal, in that case I would go for a Eaton ultrashift plus, it has a hill start aid button that engages the clutch so that you don't roll back like you would be more likely to do with a regular ultrashift.
The main difference between the ultrashift and the ultrashift plus is the clutch that they use. The regular ultrashift uses a centrifugal clutch that engages as the engines rpms rise till it locks up around 1500rpm when starting off, a lot of drivers complain about the ultrashift because it takes awhile to get used to since you don't have 38th ever control of the clutch engagement like your used to. The ultrashift plus uses a electronically engaged clutch which gives it the ability to have the hill start aid that I mentioned before, drivers seem to prefer this over the regular ultrashift.
The other option would be a Eaton autoshift and it has a regular clutch with a clutch pedal so you start out just like you would with any manual transmission.OzzyOKC Thanks this. -
Thanks for clearing that up. I drove for US Xpress previously with the ultrashift, just didn't remember specifics. Haven't driven in about five years. Going through C1 school in a couple weeks, will see how my knee feels double clutching lol. Tore my ACL few years ago but it's doing pretty well. I'm sure I can make it through school but long term everyday is a definite no go.
I drove a 2010 Volvo with an I-shift for 3 years.loved it and had no problems with it.Company moved me into a 2013 Casacadia with 13 speed Ultra shift plus and while not as nice as the I-shift I like it also and had no problems with it.In August they moved me into a 2014 Cascadia with the new Ultrashift 10 speed.I find this works nicer than the 13 speed.Also haven't had any problems.I have driven automated transmissions for 10 years now an wouldn't go back to a manual.My left knee doesn't hurt anymore and after 10 hours driving I find you are not as tired.
rpcrown Thanks this. -
your choices are
Volvo I-shift
nly in a Volvo with a Volvo engine, would be my 1st choice,
eaton fuller ultrashift: gen 1 with clutch pedal (used to start and stop ONLY) gen 2 what you had when you worked for usx, gen 3 same but different grograming (what bjytech said is right for the most part but the clutch locks up at about 850-900rpm's not 1500) it takes time to learn how to slip it when backing),
eaton fuller ultrashift plus: only thing I know about this one is it's the reason USX stopped getting auto's.....! all the 2010 usx had started to burn out clutches in the 1st 100k and when you have over 1,200 new trucks burn out clutches in less than a year, most in less than 6 months (teams get the new trucks)
meritor freedomline : works the same as the ultrashift -
Anyone driven an Allison 6 speed auto?
Yeah I have, good transmission depending on the weight used for
What weights were you at that you liked it? What was the entire drivetrain?
Thanks! -
auto for noobs. They don't know what is trucking legitly.
Oh brother!!!! Here we go again, with this super trucker crap.
