autoshift transmission
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 6wheeler, Sep 20, 2013.
  1. 6wheeler
    6wheeler Road Train Member
    2,696
    4,773
    Aug 30, 2009
    I am looking at buying an autoshift, any opinions?
    I had one long time ago and it seemed as they couldn't figure out how to backup!could figure out how to slip the clutch
    mje Thanks this.
  3. Casual Trucker
    Casual Trucker Medium Load Member
    495
    326
    Sep 7, 2012
    Good trany expensive to repair but good trany
    mje Thanks this.
  4. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Which autoshift?
    There are many out there.
    some are just bad while others are brilliant.
    mje Thanks this.
  5. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    I had an auto shift and after awhile I could back it so smoothly that when I backed into the trailer all you could hear was the sound of the fifth wheel locking. Other guys sounded like they were in a demolition derby. If you want more control then get a three pedal ultrashift.
    mje and JohnP3 Thank this.
  6. pupeperson
    pupeperson Light Load Member
    216
    203
    Jun 9, 2013
    I don't thnk the 3 pedal models are even available anymore on new equipment. The latest Ultrashift is called an UltrashiftPlus. It's a two pedal model w/no clutch pedal. It's smooth as butter, at least when new. Put it in gear and absolutely nothing happens until you step on the throttle, and then it just gently moves off like the best driver you've ever seen. Pretty incredible, actually.
    mje and deming807 Thank this.
  7. ShortBusKid
    ShortBusKid Heavy Load Member
    955
    1,269
    Dec 5, 2010
    Vegas
    The I shift from Volvo is the best in my opinion. I had one in a 2011. Truck was another story. I also have driven an 07 and an 09 with the Ultrashift. They are ok and I would probably buy one again. You can't beat them in heavy traffic.
    Scania man and mje Thank this.
  8. BJnobear
    BJnobear Heavy Load Member
    969
    306
    Aug 24, 2010
    PCB, FL
    I test drove one today. US+ 18 in a 587. I liked it, but upon talking with the mechanics I ran the other way...FAST! :biggrin_2551:
    I can shift my own gears thank you.
    mje Thanks this.
  9. Computertrucker
    Computertrucker Light Load Member
    80
    25
    Sep 7, 2013
    I do believe Volvo is the only company that seems to have perfected it at least in terms of reliability. Their Ishift is pretty amazing
  10. pupeperson
    216
    203
    Jun 9, 2013
    What negatives did the mechanics have to say about it? I know they've had some x-y shifter problems in the past but they're now offering a standard comprehensive 500,000 mile warranty with extra warranty available if you want it. The advantage to the Eaton, at least as I see it, is the basic transmission is absolutely bulletproof - its a regular 18 speed manual - with a standard 2 plate ceramic clutch the controls of each being electronically controlled by an ECU and electric motors. I know the older models with the centrifugal clutch were bad, but I see no reason that these new ones can't be as good as Eaton claims they are. Heck, if they can electronically control an engine, controlling a clutch and a couple of shift rails should be childs play..
    deming807 and mje Thank this.
  11. vangtransport
    vangtransport Heavy Load Member
    863
    2,837
    Apr 14, 2009
    I drove the I-Shift the other day & absolutely fell in love with it.
    mje Thanks this.
