AVERAGE height of "typical" KW, Pete, etc. tractor
Discussion in 'Ask An Owner Operator' started by Scooter HBG, Jul 10, 2021.
  1. Scooter HBG
    Scooter HBG Light Load Member
    66
    65
    Apr 16, 2020
    Someone please tell me the average, typical height of a sleeper tractor.
    Before y'all start howling about "too many variables", just a ballpark number will do.
    Something like, "A typical sleeper cab will run between X ft. to X ft in height" .......
    THANK YOU!
  3. bad-luck
    bad-luck Road Train Member
    3,300
    6,066
    Nov 16, 2013
    Baltimore, Maryland
    Problem is there are to many variables.....
    Could be a flat top, or stand up. And then the height of the stacks is the most important part. And let's not forget tire size....
    Rollr4872, Last Call, Bean Jr. and 3 others Thank this.
  4. skallagrime
    skallagrime Road Train Member
    3,856
    9,943
    Apr 10, 2012
    Indiana
    I have to assume youre talking midroof to condo cab not coffin or flattop
    My kw t600 midroof runs 11'-6" but condos on tall rubber are going to be pretty close to the 13'-3"
    Bean Jr. Thanks this.
  5. Arctic_fox
    4,090
    21,246
    Sep 16, 2016
    Anywhere from 10' at the low end to 14' at the high end. Thats why there is no average height. Just a range a rig can be in. So many bloody things affect it.
  6. abyliks
    abyliks Road Train Member
    3,898
    9,129
    May 2, 2010
    ludlow MA
    I’m 13’ 4” to top of the stack, 10-12’ to top of the cab
  7. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,058
    Nov 18, 2014
    Land of local
    I'm 11'4 with a mid roof on small rubber. A lot of condos are right around the 13 mark and flat tops right around 10 maybe even a hair under. The stack on my mid is a little shorter than the cab
  8. Ruthless
    Ruthless Road Train Member
    8,957
    88,244
    Aug 28, 2010
    The City.
    9’ to the top of the bunk
    singlescrewshaker and Bean Jr. Thank this.
  9. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    13'6".
    Or accept the fact that there are indeed too many variables. Exhaust stacks are probably the biggest factor for tractor height.
  10. AModelCat
    159,412
    13'6 is typically max legal height. Flat top with no stacks is probably in the 9-10' range. Car hauler specs would probably be even lower.
  11. Scooter HBG
    66
    65
    Apr 16, 2020
    THANKS!! to all who took the time to reply.
    Got to admit feeling dumber than dirt here...
    Building a 40' X 30' outbuilding. Want a door opening that will allow me to pull tractor in to service it.
    Contractor asks, "How high for the roll-up door?" I look at contractor with "Deer-in-Headlights Look" and reply, "I don't know."
    Yeesh!!! Spent over an hour trying to google tractor height, etc., no luck..........
    Contractor "ballparks" construction cost at "Anything over 8' add $3,500 to $5,00 per foot."
    Haven't bought tractor yet, looking for used older rigs, pre ELD and Emissions....
    Again, THANKS!! all. Live and learn.............
