axle interlock
Discussion in 'Trucks [ Eighteen Wheelers ]' started by chrisut, Mar 19, 2013.
  1. chrisut
    chrisut Bobtail Member
    19
    Mar 13, 2013
    I'm sorry if this sounds like a dumb question, but how does the axle interlock work?
  3. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    Your front pumpkin essentially has two differentials in it. The first one divides the power between the front and rear differentials. The second one is your front differential and acts like the differential in your rear pumpkin, it splits the power side to side.
    When you lock the power divider, you're forcing both front and rear differentials to turn the same speed. Essentially instead of just one wheel spinning, now you need two to spin in order to get stuck.
    A common misconception is that the front differential receives no power unless the power divider is "engaged". This is completely false. All four wheel ends receive power regardless if the interaxle is locked or not.
    123456, WitchingHour, heyns57 and 3 others Thank this.
  4. Hammer166
    7,572
    27,593
    Aug 18, 2007
    ~8600+' and loving it!
    :biggrin_25514::biggrin_25514::biggrin_25514::biggrin_25514::biggrin_25514::biggrin_25514: Clear, concise, and absolutely correct!
    Now, prepare for the idiocy to follow...
    123456, WitchingHour, MJ1657 and 2 others Thank this.
  5. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    Depending on the rear end should be added to your statement. The old rockwell rears that have the thru shaft do not drive the front axle at all unless the power divider is engaged. The only way there is power to the front rear is if the actuator moves a slip yoke on this shaft and engages the splines and allows the main shaft to turn the power divider.
  6. allan5oh
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    There's exceptions to every rule, and that would be it.
    There's also "common knowledge" out there that you should run with the interaxle locked all the time. This is a huge mistake, it wears tires out faster, and puts substantial strain on the power divider. Slippery/wet conditions only.
  7. chrisut
    19
    Mar 13, 2013
    is it something that can be added at some point or do you have to have a rear end specifically designed for an interlock? I have two trucks with an interlock switch, and two without.
  8. Hammer166
    7,572
    27,593
    Aug 18, 2007
    look at the divider in the trucks, it's possible the lock is there and just not plumbed to a switch.
    From Tapatalk- for when you're really addicted.
  9. chrisut
    19
    Mar 13, 2013
    what should I look for? the ones that don't have the switch are a mack with the camelback suspension and a pete with airride suspension
  10. Hammer166
    7,572
    27,593
    Aug 18, 2007
    look at the trucks that have them. You will see the actuator with the airline going to it on the front half of the front rear. You'll know what to look for on the others. Some Mack rears have a limited slip design to the power divider, no external control. Take the vin to dealer, they can tell what you got. Same for the Pete. If you can find a knowledgeable parts guy, anyways.
    I'm away from truck or I'd snap you a pic.
  11. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    Engage before entering slippery conditions. It does you no good once your stuck.
    Our freighshaker even has full locking diffs in rear axle.
    Good to have when deliverying to jobsites with flatbed
