Axle weight distribution on an oversize load - Question
Discussion in 'Flatbed Trucking Forum' started by Oscar the KW, Jan 12, 2012.
  1. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,119
    May 19, 2011
    I am supposed to pick up an oversize load that is 44'4"x11'4"x10'2" and 45,000lbs. I have a 38' bottom deck, so I will have 6'4" of overhang. This can be permitted for. My question is will I have any trouble with weight distrubution? Making sure my axle weights on the trailer are good to go.
  3. kubotaorange76
    kubotaorange76 Light Load Member
    269
    89
    Apr 9, 2010
    Monticello, Ga
  4. Oscar the KW
    12,247
    28,119
    May 19, 2011
    Truck and trailer is 34,000. Trailer alone is 10,500.
  5. haulhand
    haulhand Road Train Member
    You'll be close but I don't think you'll have any trouble axleing it. Make sure if it has a heavy end you load it up against the neck.
    - Sent from my iPhone using Tapatalk
    Mommas_money_maker Thanks this.
  6. fortycalglock
    fortycalglock Road Train Member
    6,159
    6,598
    Jun 25, 2011
    Tourist Town, FL
    You should be fine if the piece is fairly uniform. With only 45k, you,d be hard pressed to hit 40 on the spread. You might want to only order one state in case the weight is on the light side.
  7. Oscar the KW
    12,247
    28,119
    May 19, 2011
    That is my thought as well, putting the heavy end up against the neck. If there is one. Its supposed to be some type of little building for an electric company.
  8. Mommas_money_maker
    Mommas_money_maker Road Train Member
    1,122
    765
    Oct 2, 2011
    North Carolina
    I agree with the others, put weight as far forward as possible and only order one state for now, you should be fine
  9. Oscar the KW
    12,247
    28,119
    May 19, 2011
    No permitted load will be allowed to travel into or through the area bounded by I-285 (Atlanta bypass), unless the vehicle is making a pickup or delivery within the area. The driver must be prepared to show proof of such pickup of delivery. In addition, a permit issued for the movement of a vehicle or load is not valid between the hours of 6 a.m. through 9 a.m. and 4 p.m. through 6 p.m. Monday through Friday. Parking on the interstate and limited access highway rights-of-way will not be allowed for permitted vehicles waiting for authorization.
    Am I reading this correctly? No permitted loads inside the beltway within those hours, but I-285 is ok for travel within those hours?
  10. haulhand
    Yep that would be a curfew and sounds to me that they will allow travel around the loop but not inside it. Indianapolis is the same way you can run 465 during curfew but not inside.
    SHC and Oscar the KW Thank this.
  11. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
    Yep, u can run 285 all day long, as long as that is the route they issue you.
