B/W 198123 turbo
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 379CAT, Oct 14, 2010.
  1. 379CAT
    379CAT Light Load Member
    114
    20
    Feb 10, 2009
    springdale wa
    i have a B/W 198123 turbo on my truck, i want my jake power back what can i do,, smaller exhaust housing? anybody have a part #? any other turbos i could use? i just have 58's and i fuel wire right know. but i will be getting a 7cz flash before long, but if i cant get my jake power go this turbo will be going up for sale
  3. josh.c
    josh.c Road Train Member
    1,105
    420
    Feb 22, 2009
    Knoxville, Tn
    Put the boat cam in it maybe?
  4. power freak
    power freak Light Load Member
    220
    60
    Apr 23, 2009
    There is a better turbo for your application that will give you back your jake and spool quicker. It is a borgwarner and from what i've heard it is the same turbo that pdi sells as there stage one. Here are the part numbers
    Compressor-175958
    Cartridge-175964
    Turbine housing-171698
    C-16 turbo- 175963
    you can get the c16 turbo and the 171698 turbine housing and just swap the turbine housing.
  5. rollin coal
    rollin coal Road Train Member
    13,482
    27,521
    Mar 29, 2008
    TN
    I run the turbo powerfreak posted it spools and jakes very well. Turbo exchange in NC is where I got it for $1650 plus $38 shipping. You might have to wait for one though they are hard turbo to get. PDI sells them for $2400 or so. Not sure what kind of power youre putting down but this turbo is good for 700/750hp or so. editted...Just read your sig 7cz flash, fuel temp wire, and this turbo will be good you will be happy..
  6. nsane4
    nsane4 Bobtail Member
    38
    4
    Sep 25, 2010
    abingdon va
    the turbo that they are talk about is great. i know where you can one but it well first of nov.
  7. 379CAT
    114
    20
    Feb 10, 2009
    springdale wa
    so should i just trash can this turbo i have and get the turbo? i will be runnin 58's and a 7cz flash file
  8. power freak
    220
    60
    Apr 23, 2009
    I have a truck running the same setup 58's, that turbo and a 7cz flash and it is pretty strong and still has a good jake. You could sell that turbo and try to make back some of what you otherwise would have lost, that 198123 is better suited for a mechanical cat.
  9. 379CAT
    114
    20
    Feb 10, 2009
    springdale wa
    what kind of egt's are you seeing with that setup? what boost? is it wastegated?
  10. power freak
    220
    60
    Apr 23, 2009
    never over 900 it is non wastegated
  11. 379CAT
    114
    20
    Feb 10, 2009
    springdale wa
    thanks for the info. looks like thats what i will be doing then, so i need to buy the whole turbo then change out the exhaust housing?
