Back aisles has abs sensors but the rear doesn't.
Discussion in 'Ask An Owner Operator' started by Ikamob01, Oct 15, 2022.
  1. Ikamob01
    Ikamob01 Medium Load Member
    314
    195
    Dec 4, 2021
    The rear of my trailer aisles doesn't have abs sensors. I bought it this way dint know know till today.
    1. Will dot look for sensors if they pull me over
    2. Should I install sensors or just leave that way. (They said I will need new type of wheels to install sensors. I'm confused!
  3. Big Road Skateboard
    6,236
    34,358
    May 2, 2021
  4. Ikamob01
    314
    195
    Dec 4, 2021
    I really appreciate your feedback. Someone told me it was fine too. But can you add more words. Like what do you means it's fine.?
    Rideandrepair Thanks this.
  5. Big Road Skateboard
    6,236
    34,358
    May 2, 2021
    You're legal with 1 axle having ABS sensors, the valve will still control all 4 positions.
  6. Ikamob01
    314
    195
    Dec 4, 2021
    Wow! Are you for real? Thanks for your feed back.
  7. Goodysnap
    Goodysnap Road Train Member
    3,718
    9,033
    Jul 12, 2017
    The system you have is designed to work with only sensors on 1 axle. During an ABS event or when a wheel locks the system dumps air from all four wheel positions.
    Some trucks are the same and only has sensors on 1 drive axle.
    They are named as 2S 4M in the case of your trailer or 4S 6M stands for 4 sensors and 6modulator’s or ABS valves and so on depending on the system.
    With the advancement of Traction control and stability control most all newer equipment with have sensors on all wheel positions.
  8. AModelCat
    159,407
    Pretty standard setup.
    A relative of mine bought a brand new tridem trailer about 20 years back. Bit foggy on the details but I think it was a 4S 6M system and one of the axles would chew through brakes faster than the others. Ended up having to convert to 6S 6M to balance out the brake wear.
  9. Rideandrepair
    17,344
    56,270
    Aug 8, 2015
    Must be a spring ride Trailer. I have an air ride with a 2S4M system. Sensors are on the rear axle only. The reason being, on a spring ride, the front axle supposedly will lock up first. Air ride rear axle will lock up first. Other axle automatically follows. I like the system. Less sensors, wires, and cheaper valve. Only drawback is not getting an abs light if for some reason a wheel end is running loose, on the axle w/o sensors. Something that should be checked occasionally anyways.
  10. Big Road Skateboard
    6,236
    34,358
    May 2, 2021
    Much better description than mine!
  11. Ikamob01
    314
    195
    Dec 4, 2021
    I see where you're coming from but this one is a 2003 trailer.
