BACK TO BASICS: the fuel "crossover" line:
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Powell-Peralta, Feb 27, 2010.
  1. Powell-Peralta
    Powell-Peralta Road Train Member
    1,585
    240
    Jul 17, 2007
    Ok, so i've been driving a while and never really got into this particular topic; i guess i was too busy plus i didn't give a crap. But i'm thinking of getting my own tractor, so i want to learn as much as possible etc.....
    What is the deal with the line that connects the 2 fuel tanks?
    a) Does this mean i could, technically, only fill one tank. i would have to fillup more often, but it seems like you would only have to fill one side.
    b) why is it there in the first place? What does it do?
    c) Why don't you just tell me everything you know about it. All the details. No detail is unimportant or boring for me as, again, i'm thinking of getting my own truck.
    user135711 Thanks this.
  3. musicmaker
    musicmaker Medium Load Member
    561
    145
    Dec 25, 2009
    Fort Madison, IA
    The fuel crossover line comes from years ago, when trucks would only pull fuel from one tank, thus the fuel would flow from the other tank to keep the tanks equalized. Some of the newer trucks pull fuel from both tanks and dont even have a crossover line.
  4. bulldozerbert
    bulldozerbert Medium Load Member
    622
    240
    Oct 5, 2008
    Ontario
    These systems are called top draw. The draw from both tanks, to a "T" in the middle. They also have a "T" on the return line.
    I believe I read somewhere the return lines have a tube that goes to the bottom of the tank. So if you fill only one tank, the tank with the most back pressure will have the least amount of fuel return to that tank, until the other tank has "levelled out".
    I have yet to receive proof on this ,for I can never fit my head in the fuel tank to look.:biggrin_2559:
    One reason I believe they went to top draw is, if you happen to rip off the cross over line, you may loose a good bunch of fuel, causing a safety hazard.
    With the cross over lines, they usually only draw from one tank. So if the taps are closed at the bottom of the tanks, you will find yourself running out of fuel, with one tank still full.
    Kansas Thanks this.
  5. Kansas
    Kansas Road Train Member
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    Cool, I could never put how that worked together into my head until you just explained it. Thank Ya. If you ever figure out where you read that I would love to read it too if possible.
  6. bulldozerbert
    622
    240
    Oct 5, 2008
    Ontario
    I think I googled top draw fuel systems.
    my interest was peaked after we picked up a truck at one of our locations. I t would not start for nothing. Fuel gauge read full. We finally checked the tanks. One was full, one was bone dry. We put a few cans of fuel in, and away it went.
    In looking in and around the truck, I found out it had no cross over lines, henceforth the google check.
  7. bulldozerbert
    622
    240
    Oct 5, 2008
    Ontario
  8. bulldozerbert
    622
    240
    Oct 5, 2008
    Ontario
    silver dollar Thanks this.
  9. Kansas
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    I learned a lot from both links thank you. Would be nice if we could stick our heads down in there, and take a look around wouldn't it lol.
    I suspect my fuel system is picking up air from time to time. One of these days I will take the time to pull the pickup system from both of my tanks and see whats what. I may even go as far as to dump my Davco, and add a FASS or AirDog.
  10. bulldozerbert
    622
    240
    Oct 5, 2008
    Ontario
    Just do not smoke while you are doing it. haha
