Backing an automatic
Discussion in 'Questions From New Drivers' started by TheRedskinsWay, Feb 5, 2012.
  1. TheRedskinsWay
    TheRedskinsWay Light Load Member
    174
    36
    Mar 11, 2011
    Columbia SC
    So I've been issued an automatic last Saturday. Sometimes when I'm taking awhile to back and having trouble getting into a hole the display screen well say "CA". When that shows up I barely can get it to move and when it does move it moves bit by bit while the truck,trailer and me bounces around crazy left to right. What is this CA thing and am I doing something wrong and causing this?
  3. Treefork
    Treefork Road Train Member
    2,883
    1,459
    Mar 22, 2008
    Northeast Indiana
    What is the make/model of truck? Might help in looking for an answer to your problem.
    Bill104 Thanks this.
  4. TheRedskinsWay
    174
    36
    Mar 11, 2011
    Columbia SC
    Oops forgot about that!
    09 cascadia
  5. Treefork
    2,883
    1,459
    Mar 22, 2008
    Northeast Indiana
    Ok I've been searching for an answer and the only thing I can come up with is somehow, while you back you are tearing a hole in the space-time continuum and your trailer is being pushed through to CA (California) and your truck is trying to warn you and stop because that's the last place it wants to be. If its not that then I'm not sure what it is.
  6. keepntruckin
    keepntruckin Light Load Member
    208
    98
    Dec 27, 2011
    Lexington,NC
    Your just trying to change directions too quickly, allow a few seconds so the computer can catch up.
    TheRedskinsWay Thanks this.
  7. Eaton18
    Eaton18 Road Train Member
    1,755
    1,104
    Sep 3, 2011
    Waverly, KS
    I've only driven one in CDL school. It was a KW T2000, and if you did not pause in neutral when shifting from Drive to Reverse, it would not want to move. I don't recall any "CA" error message. Sometimes we would have to shut the truck off and restart it to get it to finally shift into reverse.
    The "CA" could be an error message thrown from the Smarta$$ sensor. If so it could mean "Come-on Already, you're taking too long". If you take longer than 5 minutes, it will trigger an alarm, flashing all your lights, and sounding the horn. This is to draw the attention of all the other drivers so they can start making fun of you on the CB..
  8. Shoestring
    Shoestring Light Load Member
    295
    202
    Jul 25, 2011
    Lehigh Fl
    Found this:
    Ultrashift Diagnostics
    Clutch Protection Fault
    Excessive clutch slippage creates heat and reduces
    the life of the clutch. These are some conditions
    which lead to clutch abuse:
    · Using the throttle to hold the vehicle on a
    grade
    · Starting the vehicle in too high a gear
    · Overloading the vehicle
    · Using high idle with the vehicle in gear
    The UltraShift DM TCU is programmed to prevent
    clutch abuse. When the clutch overheats, the following
    alerts take place:
    · The TRANS TEMP light comes on
    · The current gear indicator displays CA
    · A warning tone sounds at one-second intervals
    The alerts continue until the clutch cools, the throttle
    is released, or the clutch is fully engaged.
    found it here www.crengland.com/content/servicecenter/pdf/cascadia.pdf on page 143 Hope it helps.
  9. Treefork
    2,883
    1,459
    Mar 22, 2008
    Northeast Indiana
    Well those all seem like reasonable solutions. Maybe I was wrong about tearing the fabric of time...
    keepntruckin Thanks this.
  10. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
  11. double_r
    double_r Heavy Load Member
    772
    503
    Sep 6, 2008
    Pittsburgh,PA
    This is correct(thanks Jab for the info). I looked it up also in the book the company I drive for gave us when we got our autos. CA=Clutch Abuse.
