Backing Doubles
Discussion in 'Questions From New Drivers' started by toohighbronco, Apr 3, 2006.
  1. toohighbronco
    toohighbronco Bobtail Member
    Question I have is backing up doubles trailers.What technique should I use when backing up the trailers. I know there is the pin the goes into the center hole in the rear trailer the makes it a little easy on ya,but still need a little input on how to go about this. :oops:
  3. PortlandDriver
    PortlandDriver RIP, May You Be Heaventown Bound!
    335
    17
    May 30, 2005
    Pacific Northwest
    Never been able to do this with a complete set, I have backed the rear pup with the dolly on a regular basis...
  4. MACK E-6
    49,000
    227,428
    The best advice is don't. It's more trouble than it's worth, and I'm not entirely convinced it can even be done.
    Huh? :?
    Never seen any "center pins", but never looked either. Must be special kind of trailers. I'll check that out before my next run.
  5. Maxgussam
    Maxgussam Light Load Member
    145
    272
    Oct 16, 2005
    We have a driver at the Orlando terminal that has won lots of $ from people that think the same thing... There are yard jockeys that can do it as well.
    He said that he can tell as soon as he starts off with a set, if he will be able to back them or not.
    I can't back a set, in fact I'm not even going to waste the time trying to learn.
    Every once in a while, I can back the lead & gear to the rear trailer, but most often just push it into position.
    It saves me time, and I am not concerned with impressing anyone...
  6. PortlandDriver
    335
    17
    May 30, 2005
    Pacific Northwest
    It can be done, I have seen it. With a LOT of practice I could do it but since I don't pull sets much why bother...
  7. Burky
    Burky Road Train Member
    On the Michigan doubles that I uesd to pull, the rear tanker had a pin that would lock in to allow you to back the set up. It operated off of a brake type air chamber, and went into a corresponding hole in the dolly. This was a setup where the dolly under the pup was permanent, mounted with a turntable fixture rather than with a converter dolly that could be removed.. Haven't seen the backing pin used on any regular convertor dollies, so it's probably not a very common deal to come across.
  8. MACK E-6
    49,000
    227,428
    What were these? 2 45's, 48's or something?
    Oh, like fire trucks, huh?
    I thought not...
  9. rl- LTL driver
    rl- LTL driver Bobtail Member
    35
    i would do this fairly regularly when i was a jockey, now i just back the
    lead and dolly to the rear now that i drive.
    the only tips i could give is when you back up a trailer i always looked at
    my tandems, when backing a set i would just look at the dolly. what it
    does is where you are going. go slow, and once you get off track its real
    easy to start snaking the rest of the way. i would always get a little angle
    going and watch the dolly.
    the only time i would ever do it was if a set came in and they were going
    to add to the rear, instead of breaking it and rehooking i would just back
    it up and leave it. also we were buying a assload of new pups and terminal
    manager wanted us to break all of them down...even though we were
    sending them out as empties time to time. so i would back them on the
    line and make it look like they were double stacked lol
    oh and the only time i ever need to back them up as a driver, i was going
    from indy to grand rapids. i went up 131, one part of it bends to the right
    real quick and i wasnt paying attention. took me straight into a residential.
    so i backed out...good thing it was the middle of the night.
  10. Burky
    The main set I pulled was an old fuel tanker converted over for hauling liquid lime and liquid manure for farm use. 24 foot lead on 3 axles, and the pup was a 19 footer with tandem dolly and three axles on the rear. 17,000 gallons capacity, total of 11 axles on the combo, gross legal weight of 154k. Not quite as much as the legal limit, but we only had a 12 k steer axle which cuts off 6l in potential weight vice an 18k axle, and the spacing isn't quite as favorable on the shorter trailer as it could be on longer ones. Mich allows up to 164k on the right combinations, but you have ot hve the right lengths and axle spacings to make it work out right to the maximum.
    No one uses the lead/pup set up for fuel anymore. Now fuel tankers are single trailers, 8 axles set up under them in combo to get up to gross. Trailers are safer that the old setups, because they have a lower overall height and center of gravity. The old pups liked tro whip around some, and could be dangerous in winter or foul weather.
  11. Your best bet is the most work.....break 'em out and do it one at the time. It usually takes less time anyway and hey It's cheaper than the gym!
    Freebird135 Thanks this.
