so do you guys back less because your pulling a tanker? like no docks. nothing in between trucks. i want tanker but im having a hell of a time finding anything local in the chicago/indiana area. sucks. and the places you guys deliver is it like a pull in and pull out? is the $$ better than dry van?
backing in tanker
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by 4noReason, Nov 21, 2013.
Page 1 of 8
yes the money is better than dry van, expecially if you haul haz-mat (gasoline). responsibility is also higher. you have to watch that liquid surge when you turn, or come to a stop (the liquid will surge, and push you in a direction you dont want to go due to the center of gravity) chances of rollover is greater because of the liquid surge.
i don't pull tanks but my coworkers do. i have seen our guys get loaded with liquids, and can say you won't need to back into docks as much because, why do we go into docks? to open the back doors of the dry van or reefer and unload/load freight. since a tank trailer doesn't require loading like this, you'll probably be pulling up to whatever vessel is loading you with your liquid products. does that make sense? you only back into docks because there are people in that dock to unload dry or refrigerated freight. this isn't an absolute though, so you better know how to dock that truck -
Sometimes with tanker you have to do some creative backing!
379exhd, shredfit1, madagascar and 7 others Thank this. -
There are some places we have to back, and they can be just as interesting as anything else
Skydivedavec Thanks this. -
A lot of times, you do just pull in, but there are many times where I envy guys who just have to back into a dock.
Skydivedavec and Big Duker Thank this. -
If you do cryogenics you'll get better at going backwards than forwards. Most places you go are not meant for trucks at all and the tanks you deliver into are always in places that are hard to get in to.
jtwhite, Skydivedavec and Truck Driver Thank this. -
Driving a tanker has other challenges to consider apart from just backing. Fluid moves. You get slosh. Even with a baffled tank, if you have to stop too quickly or go into a curve too fast, things could end badly. There's nothing like underestimating a curve and feeling everything *luuuuuurch.*
NDBADLANDS, Skydivedavec, david123abc and 3 others Thank this.
Truck Driver, Criminey Jade, Skydivedavec and 1 other person Thank this.
Page 1 of 8
