Backing tip from a noob.
Discussion in 'Questions From New Drivers' started by telcobilly, Mar 20, 2009.
  1. telcobilly
    telcobilly Medium Load Member
    614
    163
    Sep 30, 2008
    Laying Low
    Being a noob for about 1.5 months solo, I thought of a trick that has been a good aid for me in trailer backing.
    I put a small white dot on the lower part of the steering wheel on the inside. When I start backing, I move the dot in the direction that I want the trailer to go, it's real easy to connect your mind to this when you are under the gun to get that trailer in the hole. One less thing to think about when your mind is already over taxed with the new skills you have to master. I just used my white-out to make the dot.
    Hope this helps someone..
  3. notarps4me
    notarps4me Road Train Member
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    dang it I just hit that other trailer cuz I was looking to see which way to turn the dot...:biggrin_25523:
  4. RickG
    RickG Road Train Member
    12,812
    6,136
    Jul 22, 2008
    Owensboro , KY
    GOAL !!!!!
  5. searay
    searay Light Load Member
    120
    17
    Sep 1, 2008
    Marietta, Ga.
    Just use the mirrors.
  6. Miles_Of_Truckin
    Miles_Of_Truckin Light Load Member
    260
    38
    Sep 25, 2008
    MD
    That's the key, get out and look. Even if you have to do it 10+ times, also don't let other driver's push you into rushing or making a change into what you feel your doing is right. Also anytime you can get a helper do so.
  7. notarps4me
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    Yeah, but if the helper backs you into something and walks away... your on your own...:biggrin_2554:
  8. telcobilly
    614
    163
    Sep 30, 2008
    Laying Low
    I also do GOAL/mirrors as well (obviously), but when backing is new to someone, a visual prompt makes the task easier (at least it does for me). It takes time for it to become natural where an aid is not needed..
  9. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    Anything that will help you is fine as long as you don't leave any other part out. Don't let this little trick you use take place of making sure you're not backing blind and safely. And above all do not ever let another person push you into something that is outside your comfort zone.
  10. He who is called I am
    He who is called I am Medium Load Member
    437
    98
    Dec 18, 2008
    Da U P Eh, Michigan
    I guess everyone has their own way of doing things. As long as you dont hit n e thing you are doing alright. Just dont get to confident after a few years you never have too much exp to make a mistake. Stick to your guns and never back up with doubt in your mind GOAL anytime you have a doubt.
  11. HardlyWorkingNeverHome
    HardlyWorkingNeverHome Heavy Load Member
    709
    316
    Mar 18, 2008
    Hamden,CT
    When I first started backing I used a different aid. If I was straight line backing I would throw the top of the wheel towards the trailer. This would keep it behind me. If I was backing into a hole I would throw the bottom of the wheel because that makes the trailer react in the direction I intended.
    If you can think in this manner, you save yourself from staring at your dot. I also had to learn to aim the wheels and not the back of the trailer towards the loading dock. I used to aim the back all the time and with the over hang I would get screwed up and come up short on the swing into a hole all the time. When you come up short it make it a very steep angle to correct and this is how most people swipe other trucks when first learning.
    panhandlepat Thanks this.
