Backing tired
Discussion in 'Questions From New Drivers' started by LeadFarmer, Jun 1, 2018.
  1. LeadFarmer
    LeadFarmer Light Load Member
    103
    91
    Dec 20, 2017
    I work north east regional flatbed running 5 loads average from Sunday to Friday night. It's not unusual to have back to back 13+ hour days untarping, unstrap, folding, then putting them all back on a new load and fitting 10 hours of driving in to barely make it on time for delivery.
    When I get to a truck stop late in the week I'm beat. I'll find a spot, stretch a little, get out and look at the spot. Sometimes I'll put a flashlight at the end of it so I don't go too far and can see the whole line.
    What else can I do to help up my alertness and patience? I've been lucky ending at terminals or finding/making an easy spot. Haven't had to wiggle into a tight spot but eventually that luck will run out.
  3. Chinatown
    Chinatown Road Train Member
    74,941
    170,808
    Aug 28, 2011
    Henderson, NV & Orient
    Turn on the emergency flashers while backing after dark. The reflections of your emergency flashers on the two trucks you're backing between will aid you.
  4. tlalokay
    tlalokay Medium Load Member
    473
    773
    Jun 3, 2014
    El Paso, TX
    Sounds like a hectic schedule. I'd say getting out and shaking off the road a little before backing up is your best bet. Loading up on sugar, coffee, etc., would only inhibit the much needed rest you need after getting that rig situated.
    Just passing by Thanks this.
  5. Numb
    Numb Crusty Curmudgeon
    4,073
    9,372
    Jan 30, 2012
    Charlotte, N.Carolina
    should always have flashers when backing. helps see and for safety. lets people know your intentions.
    KB3MMX, tscottme and gentleroger Thank this.
  6. LeadFarmer
    103
    91
    Dec 20, 2017
    Yeah exactly. Chemical stimulants will just make things worse.
    tlalokay Thanks this.
  7. Buster Churry
    Buster Churry Light Load Member
    184
    4,482
    Apr 13, 2018
    Up The Road
    If I were fatigued to the point of not trusting my skills, I would just pull straight into a spot and worry about backing out of it when I’m rested. You’ve gotta do what ya gotta do to make it to another day.
  8. OCC
    OCC Bobtail Member
    12
    8
    Sep 20, 2017
    I try to always park at the next mornings delivery. Saves your clock in the am while unloading and backing when tired isn't an issue. I fuel up and get a shower mid day when the truck stops are empty.
    bryan21384 and Truckermania Thank this.
  9. Trucking in Tennessee
    Trucking in Tennessee Road Train Member
    3,740
    5,740
    Mar 19, 2018
    Nashville
    The country operates on a 40 hour week. Yet we are expected to put in up to 14 a day, not sitting at a desk but operating 80,000 pounds 70 feet long. Insanity. Posted this before but try B-12. At the very least it's good for you. I know the rule is GOAL, but when you are at 14 hours and have done this about 20 times already it's rough. We had a gravel yard with no lighting. One driver did what the other poster suggested-drove in instead of backing. Got stuck and caught hell. Some days you can't win.
    LoneCowboy Thanks this.
  10. buddyd157
    buddyd157 Road Train Member
    13,564
    34,840
    May 25, 2017
    under a shade tree
    it is not unusual to be more tired doing regional than OTR. i have done many jobs and yes, regional you just get more worn out.
    as far as backing, do it slower than normal. maybe if possible, on your "30", take a power nap. but make sure, it is NO MORE than 30, set the alarm clock, whether you put your self over the steering wheel or the bunk.
    at the time you get to a truck stop in the north east, you can't really find much parking at any truck stops or rest areas.
    in your particular situation, you really may want to consider the reserved parking at the truck stops, and turn in the receipts for reimbursements. if your company refuses to reimburse you?
    seriously, there ARE other flatbed companies in N. E.
    BillStep Thanks this.
  11. Ridgeline
    22,401
    116,472
    I would first have them push the delivery times a bit more, no excuse to run that tight.
    If not I would look for another job, you won't make it and life is too ****** short to kill yourself over this crap.
    austinmike, KB3MMX, kemosabi49 and 2 others Thank this.
