Backing up a flatbed trailer is no joke
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by C.S.T, Dec 5, 2017.
  1. C.S.T
    C.S.T Light Load Member
    149
    65
    Nov 15, 2017
    Straight backing I did OK. Offset backing, parallel backing, and alley dock backing is so hard. I feel like I'm in backing hell. I need the secret to backing up
    shanecruz01 Thanks this.
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    If you are able to back straight, you can back and follow a trailer around at any angle all the way in.
    If you treat the trailer like a car with the whole tractor and all it's wheels as just the steer you will do better.
    C.S.T and Puppage Thank this.
  4. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    Look at tires instead of van body like you may be used to doing?
    C.S.T and tscottme Thank this.
  5. Lonesome
    Lonesome Mr. Sarcasm
    11,175
    22,941
    Dec 15, 2007
    Northern Indiana
    I agree, watch the tires, and don't over correct!
    C.S.T Thanks this.
  6. gpf87
    gpf87 Heavy Load Member
    765
    882
    Feb 2, 2017
    split axle flatbed ?
    I agree they are a complete pain in the butt . A dump valve really helps for the sharp angles !!
    Justrucking2 and C.S.T Thank this.
  7. C.S.T
    149
    65
    Nov 15, 2017
    I will give it a try again tomorrow. This time I will stare at the tires
  8. Pete jockey
    Pete jockey Medium Load Member
    502
    518
    Feb 28, 2015
    North of Pittsburgh Pa
    Use dump valve if equipped. You definitely don’t want to over cut
  9. C.S.T
    149
    65
    Nov 15, 2017
    I tried offset backing this morning and mess up so I went to blind side parallel and did that on my first try without no pull up. I 'm getting there. Anything that is man made, I can conquer it. I just boosted my spirit level up. Now I feel like I can do anything now.
    Lonesome and ladr Thank this.
  10. gpf87
    765
    882
    Feb 2, 2017
    That's a good mindset to have .
    Another thing that sucks about those split axles is they wil back differently when you're really heavy . I really can't stand when people make fun of "flatbedders" backing .
    did you find out if your trailer has a dump valve ?
  11. C.S.T
    149
    65
    Nov 15, 2017
    I have ideal. It's cypress truck lines flatbed. After lunch break I tried offset backing again and I did it. I wasn't taking advantage of my pull ups and making imaginary line on the payment. Now I have the concept of it now
    Lonesome Thanks this.
