Backing up split axles
Discussion in 'Questions From New Drivers' started by Brandon1285, Apr 6, 2011.
  1. Brandon1285
    Brandon1285 Bobtail Member
    21
    Feb 8, 2011
    I just started flat bed about 4 weeks ago, I got everything down, except, backing.Im ok, but if i have to back into a steel plant to pick up coils, i have trouble, why are those split axles so touchy?
  3. CBtalker205
    CBtalker205 Light Load Member
    134
    64
    Oct 30, 2008
    Pittsburgh, Pa
    Its because the rear axle becomes the pivit when backing. Whereas the front axle is the pivit when goin forward. So you have to make your move a little later then you would on a regular tandem trailer. Its just one of those things that you will have to pick up. I suggest if you have a yard to practice in just give it a few back-ups and you will have it.
    panhandlepat and beancounter Thank this.
  4. Allow Me.
    10,742
    12,468
    May 28, 2009
    Rancho Mirage, Ca.
    If you have a dump valve, use it. That way, you are basically backing on one of the two axles, makes it easier.
  5. notarps4me
    notarps4me Road Train Member
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    Since your new to flats. We got to get your terminology right. That be a spread axle.:yes2557:
  6. REDD
    REDD The Legend
    6,237
    4,291
    Jun 29, 2009
    Dueling Banjoville
    Take the advise of notarps & the next thing you know....
    You'll be locking down your load!
  7. panhandlepat
    panhandlepat Road Train Member
    3,255
    2,243
    Jan 12, 2007
    as long as you dont have to "jack it" hard and slide an axle across the ground(flat spotting tires) backing a spread is SOOOO easy. the pivot point NEVER changes backing up. I love backing my 48' spread
  8. notarps4me
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    I see your memory is about as good as your driving skills...:biggrin_2559: The last newbie was locking down his load. I helped him with his terminology as well. He was also using that crow bar thingy....called a winch bar...:biggrin_2559:
  9. REDD
    REDD The Legend
    6,237
    4,291
    Jun 29, 2009
    Dueling Banjoville
    YEP! Totally awesome in a radical narly way!
  10. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,144
    Apr 1, 2011
    Broomfield, CO
    Careful with the dump valve, though.. maneuvering that thing with the dump valve engaged can make it even more touchy, because now you're pivoting on your front axle backing up, and the remaining eight feet is swinging about.
    AZS Thanks this.
  11. Prairie Boy
    Prairie Boy Road Train Member
    3,258
    1,914
    Nov 18, 2010
    Edmonton, AB
    Also known as a "snipe".
