backup lights...DEAD!
Discussion in 'Peterbilt Forum' started by bigdawgtrucker51, Jan 8, 2015.
  1. bigdawgtrucker51
    bigdawgtrucker51 Bobtail Member
    5
    4
    Jan 8, 2015
    Huntsville,TX
    OK, so here is my issue. I have a 99 Pete 379 with a cummins n14. I have replaced the backup light switch and i am still getting no power to it. I need help, is there a fuse or something i am missing here. I am about up the wall with this. Any help would be greatly appreciated.
  3. QUALITYTRUCK
    1,810
    1,773
    Jun 14, 2009
    romulus,mi
    most OEM's share power to the back up light switch with the air dryer heater power.See if you have 12 volts at 2 pin harness at air dryer.If not,you are on the correct path to repair.good luck.
  4. bigdawgtrucker51
    5
    4
    Jan 8, 2015
    Huntsville,TX
    and if i do have power at the air dryer then what? and if i don't is there a fuse?
  5. 4x4_Welder
    4x4_Welder Medium Load Member
    300
    213
    Sep 16, 2014
    Eastern Orygun
    I just went through this with a 2008 388. The reverse light power came from a fuse marked "Spare Accessory", so make sure all your fuses are in and good. On that particular truck, someone pulled the fuse out for whatever reason. When I put the new one in, it was fine.
  6. bigdawgtrucker51
    5
    4
    Jan 8, 2015
    Huntsville,TX
    all right i will check all the fuses this weekend. anyone else have any suggestions?
