Bad deal.
Discussion in 'Experienced Truckers' Advice' started by BRD TRANSPORT, Mar 23, 2024.
  1. BRD TRANSPORT
    BRD TRANSPORT Light Load Member
    184
    69
    Jul 6, 2018
    Took my truck into KW,I have a Pete.
    A mechanic is a mechanic.
    I asked for a new oil pan seal it was leaking.and a inspection and replace a few things.
    So now I got same leak on my oil pan and it seems it has a hard foamy substance where it it's still leaking.
    I need this shop sometimes so how should I approach this thing with them.
  3. pavrom
    pavrom Road Train Member
    3,216
    7,408
    Apr 29, 2012
    NE illinois
    you asked to fix the leak or replace the seal?!
  4. BRD TRANSPORT
    184
    69
    Jul 6, 2018
    Replace seal and oil.
    When they said the did not change filters when I said cat filters only I got kind of nervous. Picked up truck drive 2 miles and parked it locked it up I was so dam tired to go home.
    Anyways I come next morning today intact and saw a puddle same place as other puddles in front of my truck.Got under to look and noticed a hard foamy substance where the leak was befor.
  5. JolliRoger
    166,908
    Subject of wide interpretation on how much to do. Old days, shop would have examined the work, considered best to do to "FIX" the problem.
    Now, drop pan, stick on gasket. No consideration for when the oil may have been coming from above, or a nice gouge in the edge of the pan.
  6. AModelCat
    164,664
    I agree that's the proper way, verify the customer's diagnosis was correct. Seems like these days some shops will take the customer at their word, do the requested repair and then kick it out the door without actually verifying it.
    The fact there was oil dripping down onto the ground afterwards kinda makes me think maybe it was a front structure leak or a front crank seal and not the pan gasket.
    Dunno what engine OP has other than its a "CAT" but I bet that foamy stuff they're seeing is some kind of sealant where the front structure meets the block or, in the case of a puzzle-piece pan gasket, sealant where the pieces of pan gasket are joined.
    JolliRoger Thanks this.
  7. OlegMel
    OlegMel Medium Load Member
    613
    1,038
    Apr 8, 2023
    What you should do is clean the oil pan and surrounding areas and let the truck idle to make sure it’s the actual oil pan leaking and not something else. If it’s the pan than they can fix their mistake. If it’s not than take it somewhere else, I know it’s hard to find a good mechanic in this country since the standards are very low for everything, but find a decent one and stick to him. Preferably one who does same makes and same engines on daily basis. Will save you a lot of trouble in the long run.
