Bad DEF quality and Nox sensor ? Check engine lights but they come and go
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Sekhri, Aug 18, 2017.
  1. mhyn
    mhyn Road Train Member
    4,255
    4,513
    Dec 29, 2008
    Northridge, CA
    take it to Detroit dealer. they can fix it.
  3. NightTruckerstreetlightx2
    NightTruckerstreetlightx2 Bobtail Member
    21
    4
    May 24, 2019
    I went to freightliner and it was temp fix I don't want to have to replace the whole thing. F.Y.I if you want to foece regen a Detroit turn on, idle 2 min, clutch in, shift to first, back to neutral, press regen button. Started right up lets see if I can regen the dpf yellow off. P.s. filter and 400 bill didnt turn off light and 400 dollar bills to turn regen on could have been saved had anyone told me I could shimmy a switch. Just wasted thousands officially. Heck, it was online.
  4. danny23tx
    danny23tx Road Train Member
    1,494
    2,324
    Feb 16, 2016
    Austin,Tx
    Yeah if you dont have the Software you just end up replacing parts until it works and even than you need software to reset everything. OtR sales a device that has alot of features that can help keep you moving , might save a huge tow bill . Good luck
  5. NightTruckerstreetlightx2
    21
    4
    May 24, 2019
    Guess what.. Back in action. I did a manual forced regen by clutch twice and the little yellow dpf light went out red light off lost two faults and I'm no longer sedated. Awesome!!! I just saved thousands if not the whole thing. Also, I lost thousands taking it to the shop when all it needs is shimmy ya. My guess the sensor goes out and you have to proactively force a regen twice a week or god forbid do a few when the light comes on. Yiud think the dpf lasts as long as the engine but there are some backward thinking. Thanks.
    MartinFromBC and danny23tx Thank this.
  6. mhyn
    4,255
    4,513
    Dec 29, 2008
    Northridge, CA
    :biggrin_2559::biggrin_2559::biggrin_2559::biggrin_2559:......:biggrin_25512: Why you want to do parked regen? You have a problem with SCR. Do you know how things work in 1-box?
    roshea Thanks this.
  7. mhyn
    4,255
    4,513
    Dec 29, 2008
    Northridge, CA
    software is not enough. You need to understand how system works. There is only one thing you can reset by software. Problems must be diagnosed and fixed . Knowledge needed.
    spsauerland and roshea Thank this.
  8. NightTruckerstreetlightx2
    21
    4
    May 24, 2019
  9. mhyn
    4,255
    4,513
    Dec 29, 2008
    Northridge, CA
    Yeah men do parked regen every second day or every day....
    uncleal13 Thanks this.
  10. simonsocm
    simonsocm Light Load Member
    109
    64
    Aug 17, 2019
    FYI for anyone that has this problem. Change out your differential pressure sensor for your dpf. The sensor is less than $100 and is only two small hose clamps and two very small bolts, something like 4,5, or 6 mm sockets will work. On my 15 670 it was on the front corner of the dpf so you’ll have to remove your passenger side fairing under the door. Took me 5 mins and probably saved me a buttload in diagnostic fees.
    shatteredsquare and mitmaks Thank this.
  11. shatteredsquare
    shatteredsquare Road Train Member
    1,403
    1,832
    May 23, 2014
    middle dirt
    What software do you get to clear codes and force regens?
