bad drive tires?
Discussion in 'Questions From New Drivers' started by rentamedic, Nov 26, 2016.
  1. rentamedic
    rentamedic Bobtail Member
    39
    12
    Jul 7, 2009
    louisville,ky
    I could use your/group help. I'm having a issue with my boss about the drive tries on the truck. I believe the need to be replaced but he says they are fine here is a pic of the tires tire.jpg
  3. tinytim
    tinytim Road Train Member
    5,143
    18,825
    Oct 29, 2007
    Northern Ontario
    Pics can be deceiving but they look fine to me.
    Is there irregular wear or is the depth less than 2/32"?
    Toomanybikes and CrappieJunkie Thank this.
  4. rentamedic
    39
    12
    Jul 7, 2009
    louisville,ky
    Im just use to seeing a good tread pattern on them some said ribed tires? seems like crap in rain and snow too me
  5. Broke Down 69
    Broke Down 69 Road Train Member
    2,733
    9,772
    Jul 3, 2016
    Concord NC
    Unless they are less than 2/32 those drives are fine. If the two straight grooves in the center are what's concerning you, I'd suggest learning a little about tread patterns. They are known as "channel treads" and are there specifically to move water. The outer two are known as "traction treads" they provide some measure of water removal but primarily grip the road. Different tread patterns are common and can be adapted to your particular driving/weather conditions.
    Ruthless Thanks this.
  6. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    You want different tread now that we are into winter. There are all sorts of types of tread ranging from off road cross grip all the way up to the ones you have in the pics.
    I see nothing that jumps out at me on those pics, but would measure the depth of the tread.
    Winter is here and it will be beneficial to have a fresh set of all purpose on the drives.
  7. Numb
    Numb Crusty Curmudgeon
    4,236
    9,945
    Jan 30, 2012
    Charlotte, N.Carolina
    do I have done in the past. ask the DOT at a scale house. they can then write it up ,with a warning to be fixed.
  8. MACK E-6
    49,746
    235,110
    Those look like trailer tires to me. Who would put those on a drive axle?
    Regardless, they still look good as far as wear, IMO.
    Lepton1, TripleSix, baha and 4 others Thank this.
  9. Eeyore05
    Eeyore05 Medium Load Member
    311
    287
    Nov 13, 2015
    'Sconni
    Those look like trailer tires. I know guys that only run in the south do that stuff. up here (WI) that wouldn't work 6-8 months a year.
    clausland and x1Heavy Thank this.
  10. x1Heavy
    34,016
    42,139
    Mar 5, 2016
    I was thinking the same thing, they look like trailer tires. Lets say they are.
    You introduce all sorts of problems with wrong tires on the wrong positions of the rig dontcha think?
  11. Moose1958
    Moose1958 Road Train Member
    15,266
    33,854
    Dec 17, 2010
    Williesburg, Virignia
    In this CSA age I don't recommend this action. It is potential trouble a driver and their company don't need.Tires are part of the CVSA Out of service criteria. The driver IS THE FINAL AUTHORITY of the operation of said vehicle. If you as a driver don't feel it is safe to operate don't drive it. I have refused to operate vehicles because of things that needed to be fixed OR an expired or missing permit.
    As far as those photo's go I don't see anything wrong with them at this point, but at some point in the near future they will need to be replaced.
    Toomanybikes Thanks this.
