Bad Hook - or why you always use a flashlight to look at the jaws
Discussion in 'Questions From New Drivers' started by gentleroger, Oct 18, 2020.
  1. gentleroger
    gentleroger Road Train Member
    7,573
    20,553
    Jun 1, 2010
    Last week I had a bad hook. It pass the tug test, the handle was all the way in, but it was a bad hook.
    If you look at the very right edge of the locking jaws, you'll see a little sliver of bright metal. That's an indication that your jaws are not all the way locked. The only way you'll notice this is by going underneath with a flashlight. As you can kinda of tell from the pictures, it was bright daylight, but without the flashlight I would not have seen the problem.
    Odds are the trailer would have stayed hooked, but every right hand turn the kingpin is going to try and force the jaws open. At some point, the trailer would have dropped.
    In this case I just had a little bit of grease build up on the locking jaws. I tripped them manually by using my pry bar.
    Then I scraped off the grease that had accumulated on the top of the jaws before pouring diesel fuel over the jaws and the locking mechanism while working the release handle in and out. No more problems.
    This is what a proper hook should look like:
    Notice there is no difference in the handle position
    As the weather starts to get colder, grease on the locking jaws/mechanism will slow the throw of the jaws, preventing a good hook. Most of the times this happens it's pretty obvious, but not always. Make sure you're paying attention and taking care of your equipment.
  3. Espressolane
    17,728
    109,020
    Good post. This is why, when you do your weekly lube/grease, you should clean the old dry/dirty grease from the 5th wheel. Additionally at least twice a year, preferably more often, it is good to take a degreaser and a pressure washer to the underside and jaw area.
  4. MACK E-6
    49,281
    230,799
    A Jost fifth wheel I see...
    @gentleroger Is it my imagination, or in your first pic your crossbar is dry and rusty?
    magoo68 Thanks this.
  5. mitrucker
    mitrucker Road Train Member
    5,335
    9,650
    Dec 15, 2010
    Lapeer, MI
    I can’t see the pictures.
    Rollr4872 Thanks this.
  6. 91B20H8
    91B20H8 Road Train Member
    2,946
    3,315
    Oct 17, 2012
    The Heart of the North, Mi
    Blocked out here too, good catch though:headbang: way to practice what ya preach
  7. 91B20H8
    2,946
    3,315
    Oct 17, 2012
    mitrucker Thanks this.
  8. Rugerfan
    Rugerfan Road Train Member
    7,467
    37,245
    May 3, 2011
    Redding,CA
    Can’t see the pictures.
  9. gentleroger
    7,573
    20,553
    Jun 1, 2010
    Not your imagination, but it's more the picture than reality. Turns out it's really hard to get a properly exposed picture under the trailer. I've been trying to get that first picture for 8 years.
    Now if you want to berate me for the lack of grease on the 5th wheel itself - have at it. It's got plenty to hold it until Friday when the truck goes in for a B PM.
  10. MACK E-6
    49,281
    230,799
    Not at all.
    I was simply curious if that may have contributed to what you had happen.
  11. gentleroger
    7,573
    20,553
    Jun 1, 2010
    20200923_090122.jpg 20200923_090034.jpg 20200923_085522.jpg 20200923_085522.jpg 20200923_084108.jpg 20200923_084018.jpg
    Pics in reverse order
