Bad Ignition - Ignition Off and RPM non Zero
Discussion in 'Experienced Truckers' Advice' started by TheGrimReefer, Mar 5, 2015.
  1. TheGrimReefer
    TheGrimReefer Bobtail Member
    47
    24
    Feb 11, 2015
    Any idea what that means? My company uses sattelite tracking and under "Faults" this appears a lot. I know some other faults are No Power and HARD BRAKING, but I have no idea why I get this one so much.
  3. Moosetek13
    Moosetek13 Road Train Member
    14,837
    18,729
    Nov 1, 2010
    Burnsville, MN
    You may have a bad sensor.
    TheGrimReefer Thanks this.
  4. TheGrimReefer
    47
    24
    Feb 11, 2015
    I have the MCP50, it seems from some research that it might be wiring. The mecahanics here suck.
  5. G.Anthony
    G.Anthony Road Train Member
    4,564
    5,952
    Dec 10, 2014
    Could just be a bad/defective ignition switch?
    With the humongous amount of times we turn it on and off,
    As if I were a mechanic, I'd at the very least start at that point?
  6. TheGrimReefer
    47
    24
    Feb 11, 2015
    Thanks G,
    I'll have to get them to check as this message comes up EVERY time I start/turn off the engine.
  7. G.Anthony
    4,564
    5,952
    Dec 10, 2014
    I had a pro star, my first truck at my current employer. The ignition switch was going bad, but I never got such a message. You might be lucky at least, that you get this warning of a "possible" bad ignition switch. If it is easy to get at, trust me, the mechanic will just switch it out for a new one.
  8. s0231198
    s0231198 Light Load Member
    143
    245
    Aug 23, 2008
    If you can access the wiring, check the white wire in the wire bundle and to wherever it is spliced into a 12 volt ignition switched source, sounds like it is coming loose someplace if you are getting ignition off, and check the fuse in the wiring also. The ignition source wire in my truck runs to the fuse box to a "fuse splicer" (not sure what it is called but can pull fuse out and place this in and then place fuse in back side of it and will take power from that fuse socket) that is on a ignition switched source not directly to the ignition switch.
