"Banking" idle time: A savings account for future needs!
Discussion in 'Questions From New Drivers' started by JustSonny, Mar 30, 2010.
  1. JustSonny
    JustSonny Big Dummy
    6,038
    5,785
    Oct 22, 2009
    Troutman NC
    Is it remotely possible that a carrier could allow a driver to "bank" idle time, in advance of future need, as a reward for excellent MPG, on-time percentage, or any other successful cost-saving efforts that a driver achieves? Or would that be just another can of worms that is logistically impossible?:smt102
  3. rich_t
    rich_t Road Train Member
    1,448
    77,580
    May 28, 2009
    United States
    Interesting concept.
    JustSonny Thanks this.
  4. Trucked Up
    Trucked Up Light Load Member
    69
    55
    Oct 18, 2008
    It sure as heck should be possible -- or more to the point, companies should apply some common-sense discretion when they're trying to figure out whether to chew a driver out for an isolated period of high idle time.
    But in my experience, they don't. Now whether they'd actually fire an otherwise perfect driver just for having a couple months of high idle, I can't say. Probably not, under normal economic circumstances -- but either way, they sure aren't shy about verbally beating drivers down over any little thing, irrespective of the driver's record.
    Then again, maybe I'm not contentious enough. It's entirely possible that office types dial up the aggression to 11 at the onset of every encounter because they're used to drivers who are equally aggressive at every turn. But if you're earnest and (for the most part) mild-mannered, your basic trip to the terminal sure can seem like a vacation in the Twilight Zone.
  5. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    The credits would be no good in Kalifornia.
  6. JustSonny
    JustSonny Big Dummy
    6,038
    5,785
    Oct 22, 2009
    Troutman NC
    I guess they (the credits) wouldn't be good in a lot of areas, but, for the time being, and until carriers figure out a way to keep drivers comfortable enough in the sleeper to get good rest, maybe they could be used in the areas where idling is allowed. I dunno?
    BTW, in your opinion and with your experience, does this seem do-able at all?:biggrin_25514:
  7. wildbill123
    wildbill123 Heavy Load Member
    713
    322
    Jan 31, 2009
    SE,MI
    That makes way to much sense.:biggrin_25513:
  8. JPenn
    JPenn Road Train Member
    1,829
    1,874
    Mar 5, 2008
    Northern Tier PA
    Nope. The reason being that implementing such a scheme would require both common sense and agreement between truckers/trucking companies and regulatory agencies. And most of us who've been here even a short time understand that both sense and agreement are in very short supply in this industry.
  9. Kabar
    Kabar Road Train Member
    1,041
    395
    Nov 5, 2008
    Pell City Al
    There's only one way to reduce idle time AND keep drivers comfortable. it's called an APU. Marten has then on all trucks and it's no problem to keep your idle time below 4%. 115 deg or -30 you stay at the right temp inside the cab and never run that engine.
  10. Machine
    Machine Light Load Member
    55
    14
    Mar 6, 2010
    The Road
    :biggrin_25523::biggrin_25523::biggrin_2556::biggrin_25513::biggrin_25523::biggrin_25523:
  11. brinkj23
    brinkj23 "Asphalt Cowboy"
    1,165
    322
    Dec 26, 2005
    Minnesota
    When I used to run for schneider they only complained once about my idle time and it was in the summer, all I said was hey its like a 100 degrees out here and im hot. All they said was ok well try to keep it down. When I had a truck with an apu in it, never idled the thing except for when I was getting ready to start the day and warming the truck up a little. The apu I had also kept the engine warm and didnt have to run the truck even when it was 30 below because it would run coolant through the block and was pulling fuel off the tanks with a return that also heated the fuel a little. Those apus are money savers on the engine and fuel but they do cost a lot up front, thus the reason the large carriers dont have them yet. Would've been nice to be able to bank idle time but the carriers dont think that way, they dont want to idle and dont want to fork over the money for the apus.
