Batteries test okay, but…cranks slow.
Discussion in 'International Forum' started by tarmadilo, Feb 1, 2024.
  1. tarmadilo
    tarmadilo Road Train Member
    1,721
    4,730
    Dec 12, 2018
    I’m driving a 2019 International RT with 430k on it, and it’s acting like it needs new batteries. Cranks slooow (but so far has started), and my APU runs constantly whenever I turn the engine off. Mechanic tells me that he checked the batteries and starter and can’t find anything wrong. Thoughts?
  3. Big Road Skateboard
    6,727
    37,862
    May 2, 2021
    If it cranks slow, and batteries and cables are good, it needs a starter.
    I'm curious how the "mechanic" checked them
  4. tarmadilo
    1,721
    4,730
    Dec 12, 2018
    I’m not sure. All I know is that I told them that the APU seems to think that there isn’t enough charge on the batteries, because it kicks in immediately when the engine is turned off.
    Hammer166 Thanks this.
  5. Hammer166
    7,575
    27,611
    Aug 18, 2007
    ~8600+' and loving it!
    I bet one of those batteries will fail the eyeball test and will be swelled up.
    AModelCat, krupa530, JonJon78 and 2 others Thank this.
  6. bad-luck
    bad-luck Road Train Member
    3,378
    6,253
    Nov 16, 2013
    Baltimore, Maryland
    Check all the battery cables, make sure they are tight, and corrosion free. If they are corroded, clean them with a wire brush and baking soda and water or any battery corrosion cleaner. Check battery cables for the same at the starter. This is very easy to do, I would start there.
    QUALITYTRUCK and tarmadilo Thank this.
  7. JonJon78
    JonJon78 Road Train Member
    7,216
    42,505
    Jul 1, 2018
    This thing works well and is inexpensive. A bad/failing APU alternator could be draining everything as well, how old is the one you have?
  8. uncleal13
    uncleal13 Road Train Member
    3,797
    6,297
    Apr 9, 2009
    Humboldt, Sk
    Earlier International Prostars were famous for having crappy battery cables / unprotected / not much insulation.
    Don’t know if the newer models have the same issue.
    I had a truck that the starter seemed to drag, found it was the main battery ground on the frame.
    Another truck right from the manufacturer: they put masking tape on the frame ground stud before painting, but never removed the tape before the wire was tightened down. Over a couple of years the tape deteriorated leaving the ground wire a little bit loose.
    QUALITYTRUCK Thanks this.
  9. tarmadilo
    1,721
    4,730
    Dec 12, 2018
    Well, this is happening at the Ryder shop (it’s a leased truck), and that first mechanic went home at the end of the early shift. Now we’re starting over with a late shift fellow.
  10. tscottme
    tscottme Road Train Member
    A poor/dirty cable connection between any component will seem like a dying battery. Clean off every connection and check for low resistance and good continuity.
  11. flood
    flood Road Train Member
    4,168
    4,045
    Dec 25, 2010
    Could be a bad diode in the truck alternator...
    It'll charge just fine but when you turn it off power will back flow thru it..
