Battery discharge protection system 08 freightliner
Discussion in 'Ask An Owner Operator' started by Bdot, Sep 7, 2012.
  1. Bdot
    Bdot Bobtail Member
    7
    Stockton, ca
    I might sound dumb, oh well... desperate at this point..
    The alarm sounds after a few minutes of cutting the engine. Even when nothing is plugged in cigarette light plugs. All lights off. Batteries......I believe are good. Haven't had any other battery related problems. They show green in the lil check window. I need help with this. Can't keep a fridge or charge on my phone. While driving it will start beeping too, cuts auxiliary power.
    Also strangly, it seem to activate (while driving) when I hit, or soon after I hit engine fan button
    Thanks for any and all input.
  3. Okieron
    Okieron Crusty Okie
    1,641
    1,024
    Dec 23, 2009
    muskogee, ok
    Sounds like you may have an issue with the charging system. If you haven't had the batteries load tested you have no idea if one is bad or not so start there first.
    Bdot Thanks this.
  4. Bdot
    Bdot Bobtail Member
    7
    Stockton, ca
    Thanks alot. Where can I go for that?
  5. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,214
    Sep 23, 2007
    Statesville, NC
    Any truck stop with a shop and if a company truck, you would need to contact your company.
  6. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    Does it do it when the fan comes on automatically? If so I would say check the connections on the alternator, or a wire with a break in it. Loose connections and broken wires cause strange things to happen. Just because a battery has a green light on the check window does not mean that it is good either.
  7. Sly Fox
    Sly Fox Road Train Member
    1,016
    695
    Oct 29, 2009
    Check your battery box, make sure all connections are tight (loose connections can result in poor charging). Check the fuses, as well.
    First test, as said, is go to a truck stop and have them diagnose your truck's electrical system. it's fairly cheap, and will check your batteries, draw against them, charging, etc. My guess is your batteries aren't that good, or you're not getting them charged properly but enough to keep the truck running (mostly) when going down the road.
  8. bossboy2
    bossboy2 Light Load Member
    264
    60
    Aug 20, 2011
    Houston, TX
    I would say the FIRST thing to check would be your grounds. Check to see where all your grounds attach to your engine.
  9. AUSSIE DAVE
    AUSSIE DAVE Road Train Member
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    This is true, the glass inspection only tells you if that one cell is good or bad, the only way to be sure of the battery condition is a load test
