battery voltagr issue
Discussion in 'Trucks [ Eighteen Wheelers ]' started by allan5oh, Mar 3, 2014.
  1. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    Having issues with battery voltage to the point where I don't want to turn the truck off. Changed the batteries and alternator a week ago due to same issue and these new batteries seem worse. Getting 14 volts at the batteries while truck is running. Shut it off and after a few minutes its down to 12 volts at the batteries. No hot wires or batteries but I will have a better chance to look at things tomorrow.
    My leading theory is these new batteries are junk, possibly frozen when shipped. Very cold winter up here.
  3. Alaska76
    Alaska76 Road Train Member
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    Sounds like a draw is pulling them down.
  4. allan5oh
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    I haven't checked everything but the main positive to the batteries from alternator and cab is drawing .4 amps and slowly goes down. I should check starter wires and espar wires. I think if anything was drawing it down that much my truck would be on fire.
  5. Edgar2191
    Edgar2191 Light Load Member
    178
    33
    Apr 9, 2013
    When you say a few mins do you mean Like 2 mins. Batteries resting voltage it at 12.4 ish depending on the battery its normal for them to come down but not that fast.
  6. allan5oh
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    10 minutes they're at 12 volts or less. Yesterday I shut the truck off for an hour and ran the heaters, was down to about 11.6 volts ans barely started. I've shut my trucks off hundreds of time in the same co.ditions overnight and never had this.
  7. Edgar2191
    178
    33
    Apr 9, 2013
    Something is drawing current if you change the batteries and the alt . Unless wich is very unlikely one of the new batteries is bad wich I doubt because their new . One bad battery will bring the rest down.
  8. Alaska76
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    Isolate the batteries and check them separately, may be by coincidence you have a new battery with one bad cell. That is all it takes. Otherwise you have a major draw, it could be the alternator is discharging when the engine is off, I have replaced a few for that very reason.
    It is nice to think that new parts are always reliable but once in awhile they turn around and bite when one is not looking! :biggrin_2552:
  9. Dice1
    Dice1 Road Train Member
    1,315
    609
    Jul 1, 2011
    Bessemer City, NC
    I had a battery harness wire go bad before to do what you are talking about.
    Check all wires from batteries to alternator and starter. A pin hole crack in coating around wiring can let enough moisture in to corrode the wires inside the housing.
    FYI: I like my Maxwell ESM that isolates the batteries from it for starting purposes only.
  10. allan5oh
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    Ok tool everything apart and disconnected everything including the starter cables except the espars, each gets two batteries. Will check voltage in the morning. Didn't notice any sparks when taking things apart which would indicate major draw or a dead short.
    Bad news is the truck may not start in the morning. Good news is there's a kenworth dealer within walking distance.
  11. allan5oh
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    Starter was no good replaced it and no more voltage issues. I did do a bit of wiring not sure if that helped or not. Volts are 12.3-12.4 over night running both espars. Thanks for the help.
    Licensed to kill Thanks this.
