Battries replacement for my day cab mp8 mack
Discussion in 'Mack Forum' started by atwal, Apr 11, 2014.
  1. atwal
    atwal Bobtail Member
    48
    6
    Jul 28, 2013
    Greater toronto area
    My mack gave me problem yesterday and needed a jump start in the mid of my shift when the engine was warm. I need to keep my interior trailer lights or marker lights on when working .
    So my job I need to start the truck 20-30 times a day and keep the marker lights on on most of stops from 20-50 mins
    What are the best batteries for me to replace .
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Unless you want to buy all new batteries I would remove the cables and test each one. One bad battery in the mix will cause you problems. It will read significantly lower on the voltage than the rest.
    Why must your marker lights be on? If you are running good batteries down you should try to idle more for a better balance of charging and discharging your batteries. Sometimes it's warranted in your situation.
  4. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    not sure if this is even possible, BUT can you run 1 batt dedicated to your marker lights? i would ASSUME one batt should hold up for 30-50 min of light time. not sure on how long it would take to recharge tho
