Battry's
Discussion in 'Ask An Owner Operator' started by 86scotty, Aug 15, 2020.
  1. 86scotty
    86scotty Road Train Member
    4,525
    12,256
    Aug 27, 2017
    Appalachia
    As in go check yours! I put new batteries in my truck just a few months ago and took a lot of time to clean up the bus bars, take apart the cutoff switch (which is a known failure point on my particular truck), use dielectric grease on all of the connections, etc. I took my time and did the job right. They were tight.
    Yesterday my truck wouldn't start. New starter 6 months ago. I fired up the APW and it is charging batteries, but they were showing 12.7 before I fired up APU. 13.4 while running so no problems with APU alternator. Hmmm.
    I took my cover off and reached up from the ground to start my truck and got a spark show! Jeez, scared the crap out of me. EVERY one of my 8 lugs on my batteries was barely finger tight. Apparently they will rattle loose. I'm thinking of adding lock or star washers to them this weekend and I'll definitely be adding tightening them to my regular PM list.
    loudtom, staceydude and homeskillet Thank this.
  3. Spyro2112
    Spyro2112 Medium Load Member
    604
    416
    Mar 17, 2018
  4. w9l
    w9l Medium Load Member
    316
    513
    Oct 12, 2013
    Vibration and heat cycles. Get stainless star washers. I think Lowes has them.
  5. 062
    062 Road Train Member
    6,233
    33,553
    Oct 20, 2013
    I go back over them a week or so after installing. Generally at least 4 need tightening down.
    86scotty and Brettj3876 Thank this.
  6. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    blue loctite works wonders.
    tommymonza and 86scotty Thank this.
  7. AModelCat
    160,561
    I have honestly never had a battery cable come loose on anything I've dealt with. Most times I'm just using a split lockwasher between the flat washer and nut.
    clausland and tommymonza Thank this.
