beards
Discussion in 'Questions From New Drivers' started by MarcB, Sep 11, 2014.
  1. MarcB
    MarcB Bobtail Member
    26
    Aug 9, 2014
    phx,az
    do the trucking industry care if you have a beard? cause i have a beard and i don't wanna cut it off .. i refuse too.. lol
  3. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    depednignd on the company some require clean shaven. esp during the hiring method.
    how long is your beard? some may have you trim it.
  4. 8thnote
    8thnote Road Train Member
    1,980
    3,687
    Aug 12, 2013
    Chattanooga, TN
    There may be a few companies that have some kind of policy, but I'm pretty sure most don't. I have a beard because it's just easier not to shave while out on the road.
    ramblingman Thanks this.
  5. Derailed
    Derailed Road Train Member
    2,383
    2,657
    Dec 10, 2008
    Upstate NY
    Only time I could see it being a problem is if your hauling chemicals. When I was leased on to Chemical Leaman you couldnt have one due to the fact you might have to wear a mask in the event of a chemical spill. I suppose if its long enough to pull over your mouth and nose if you had to they might make an exception.
  6. MarcB
    26
    Aug 9, 2014
    phx,az
    my beard is pretty thick.. i am muslim so is just part of my religion to keep my beard ..
  7. damutt
    1,126
    370
    May 6, 2013
    ok when you are applying be sure to emphasize it is for your religion. they will make accommodations for that
  8. sherlock510
    sherlock510 Road Train Member
    1,066
    1,058
    Jul 26, 2011
    Intercontinental.
    As long as it isn't dyed pink, you should be ok...
  9. MarcB
    26
    Aug 9, 2014
    phx,az
    I have one more question, okay i am middle eastern from Yemen. but i am in phx,az... is there a lot of immigrants out there otr driving from the middle east or Europe, africans.?..?? i heard theres some but not to much out west...
  10. damutt
    1,126
    370
    May 6, 2013
    that i dont know.. come into trucking with an open mind, and you will do well for yourself
  11. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    If it is we can just send him a few hundred miles west into your state and he will fit right in ...
    sherlock510 Thanks this.
