becoming owner operator "need advice"
Discussion in 'Ask An Owner Operator' started by mojd81, Aug 28, 2014.
  1. mojd81
    mojd81 Light Load Member
    75
    4
    Aug 28, 2014
    Marshfield, Missouri
    ok guys and gals, im really needing some advice on a few things, and any advice would be greatly appreciated. Ive been a company driver for a few years now and for the past 2 years i have been looking into becoming a O/O. I am wanting to do any type of flat bed or heavy haul. but ive got a few questions about the who O/O and flatbed thing.
    1). which is better, lease with a company or do it all myself?
    2). which is a good way to keep track of my record? all on paper or use a program or both?
    3). what are some good flatbed companies to lease on with?
    4). what to look for when picking a company to lease on with?
    5). which kind of flatbed will make the most money?
    6). what kind of truck would be best to purchase?
    7). which is best for power and autoshift or manual?
    8). what is a good ratio to get in a truck?
    9). if i run on my own which way is the best to get loads? ive heard from some O/O's that they never look for loads, that the loads find them?
    im sure i will come up with more questions, but this is it for now. thank you!!!
  3. Pahrump
    Pahrump Medium Load Member
    you can make a lot more money with your own authority,,take a lot of smarts and hard work to run on your own,,if you are good they call you,,if you are not it will be hard to get a good broker with good loads to load you again.
    Use Quicken to track and keep your financial records.
    Leased to a company that pay 90% os great but not if it is 90% of nothing,,,With all your questions and ony 2 years trucking,,think that you need to learn more before you jump, Learn how much your tires cost per mile for each tire position, how much you maintenance cost will be including a future overhaul,,how much insurance will cost by calling insurance companies,usually first year new in business will cost about $13K for everything,,,get a book Business 101 and study it,,if you are not a good businessman no matter how good you drive you will fail..If you are interested in flats,steps or heavy haul,,walk around truckstops and talk to drivers haul what you want to haul,,look and learn how the freight is loaded and secured, remember drivers and fishermen are a lot alike when taking rates,, they always tell about the best paying load they hauled but don't say much about the little one they take home,, Some times you hit a home run with a load but most times you are lucky to get to first base,
  4. russtrucker
    russtrucker Road Train Member
    1,767
    337
    Mar 27, 2012
    Central PA
    Also what you need to remember that most large companies don't pay well to o/o. Paper logs are easy to cheat and elogs (impossible). If you don't want to go to cali and not having dpf/def/scr regen, take trucks prior to 07 or a glider. CATs are well known for power/less mpg like C-15 6nz and detroit are well known with less power but more mpg like 12.7. If ur the guy to super fuel effieciency, take ultrashift. If manual, 13 sp to 18 sp are great for power and mpg. Want to speedy, take lower than 3.42. If dealing with everywhere like off road/mountain/hills, take above 3.55.
    Chewey Thanks this.
  5. RebelYeller5
    RebelYeller5 Light Load Member
    68
    31
    Mar 11, 2012
    Birmingham AL
    When I see outfits paying drivers 50K in straight salary to start, with more to follow. Really makes me wonder why anyone would tolerate the hassle and headache of being an owner/operator. You have an extensive list of questions, all those decisions, all those obligations and commitments. Seems pretty daunting. I'll tell you, if your don't have your spouse along to monitor the finances of everything and take the pulse of your enterprise, it'll be rough. Just think how thrashed your brain can get after 10 hour of driving, and instead of sleeping you're trying to deal with all that paperwork.
  6. mojd81
    75
    4
    Aug 28, 2014
    Ok thank you. And sorry about the years driving. I've been driving for a lil over 5.5 years. Just threw the profile together cause wasn't sure if it would work or not because I had an account on here but something happened to it. As far as a business person I own a restaurant and have had it for 4 years now. So your saying if I run under my own authority it should be at least 90%? And as far as insurance I have found a lot of companies that I can run under their authority, pull their trailer and they have a program for tags and insurance, and I can use their fuel card with discounts, they have tire and maintenance discounts. And as far as a truck I have been looking at either a freightliner Coronado, International ProStar, Kenworth w900l or a Pete 379 but I know Pete's are expensive to repair. I've been told the Ultrashift is really bad on snow? And I'm looking for something that can get up and go and take hills pretty good.
  7. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    mojd81 i am doing homework right now to become an o/o. starg from the bottom up. if you have a #### drivetrain the body dont mean a #### thing.
    find waht area you are going to run, mid west, sw, ne,etc. gear your truck for the terrain you are running. if you buy a truck that has 3.90 an you never see a hitll your losing money. if you buy a truck that has 2.94 an all you see is hills your screwed as well. start with engine/trans/rear/tires THEN look at body
  8. mojd81
    75
    4
    Aug 28, 2014
    Well would like to run mainly mid-west but would like to run to other areas every once in a while as well but most will be mid-west. And what is a good tire brand and size to run on a truck? And the research I've done I have found cummins are good engines and get good fuel mileage.
  9. mojd81
    75
    4
    Aug 28, 2014
    So I need to revise the area I want to run. South and Midwest.
  10. damutt
    1,126
    370
    May 6, 2013
    tires, everyoe has diff exp, stick with a lo-pro 22.5 (super common kinda cheap) . i have yet to buy a truck. ex company driver myselft. if your buying a used truck whate ever is on it, run them. i would buy tires one axle at at atime (all 4)From what i have read avoid truck stops for tires, look for smaller places or buy direct
  11. Marky84
    Marky84 Heavy Load Member
    838
    260
    Sep 24, 2012
    Jefferson, WI
    advice? dont do it. fuel prices alone.
